Trying to print ABS for first time . I set the temp in cura to 280 end and bed 90
But when uploaded to octoprint the end only goes to 240 but when printing after a min it shuts down saying errir heat to high
If I do it through just with we card it's fine and heats to the temp it should and not shut down.
Tryed SD card only
Yes
Complete Logs
