Always got an overheating or low Voltage-Message in Octoprint-Dashboard
This is not right - I am using an 3A Power-Supply an tested different cables. Also I checked the current with an USB-Meter.
Overheating is also not right - using active cooling with a fan and checked the temperature with an thermal-camera and with vcgencmd
vcgencmd measure_temp
temp=33.8'C
vcgencmd measure_volts core
volt=1.2000V
vcgencmd measure_volts sdram_c
volt=1.2000V
vcgencmd measure_volts sdram_i
volt=1.2000V
vcgencmd measure_volts sdram_p
volt=1.2250V
Is it possibel to disable the message - i am not able to install plugins.
Version: 1.3.12 / 0.15.1 on raspberry pi 3B Rev 1.2
thx for help
