ive tried to reinstall the image on the SD card
no, not sure how too
Complete Logs
so this is the third time i have setup octo print on my system first time worked great then ran into an issue with login, so i wiped the sd card and reinstalled, had an authentication issue so i deleted the .ssh file in my computer and was able to let me connect to the octopi. now it wont accept the default password
