Upload failed
Could not upload the file. Make sure that it is a readable, valid file with one of these extensions: .g, .gco, .gcode
- Nothing in logs
- Cancel Object plugin not enabled
- Octoprint worked for years and now this
- Tried to update to latest version but did not help
Is this a known problem? Best option to reinstall octoprint?
Cheers
If there is really nothing in the logs (which I can't check because you didn't provide them) I would take a wild guess and say the sd card is broken.
Try safe mode, to check it is not a plugin.
Thanks Guys for this quick reply. I already tried safe mode with same result.
I suspect this may be broken sd card. Ill try to replace it and update you here.
Thanks again!
Ok this has been the weirdest prob I experienced ever and seems to be linked to the Windows.
On my desktop PC, when I uploaded any gcode file, I received the above error message. I tried it via Chrome, Mozilla, IE, rebooting, clearing cookies, replacing raspberry pie, sd-card, reinstalling octoprint, reexporting gcode files etc. Nothing helped.
But when I later tried to load a gcode file to the same raspberry pie from my another computer - everything worked fine.
So I reinstalled my Windows 10 and all is back to normal.
Thanks to you Guys for your speedy responses and beware of M$ products, for they will shorten your life!
P.
