I got the right B+ model now - with wifi and bluetooth. Turned it on and connected to wifi right away and booted into Octoprint. I connected my v2 RPi camera and there is no stream at all.
I tried disabling some plugins I downloaded for time-lapse (Octolapse) and rebooted, removed camera cable and reinstalled it. Rebooted the Pi.
I get the "Webcam stream not loaded" error when I click on the tab to view the camera. Not sure what else to provide here or what logs to look at. This same camera was just working yesterday on a Pi 1 B+ model from 2014. Don't think it could be the camera. I am sure it is a setting or something but I am not sure where to look or what to change. Any suggestion would be greatly appreciated.
I am using a Mac so I am using Safari and also trying on my phone thru Safari as well the Octoclient app. I did remote in via SSH and went into Raspi-config and made sure camera was enabled. I also went into octopi.txt and changed the camera from auto to raspi. So far it still gives me the same web stream won't start. I am beginning to think it may be something on my router blocking the 8080 port but I can't see anything setup like that when I log into my router admin screen.
I guess I should ask a stupid question (stupid because I've done it ) Are you sure you got that flat cable plugged in the correct way? I wish there was a notch or something that prevented it from being plugged in upside down.
I thought the same thing, but no - that is not it. I checked and the blue side is away from the hdmi port. I even double checked to make sure i had it plugged in to the camera port and not display. No matter what I do - nothing happens. It has to be a bad cable, bad camera or bad Pi - but I do not have any extra around to check any of those out. All I know is that two days ago the camera and cable worked on a different board and today no camera. When I power on there is no led I an see on the camera (v2.1 raspi). Not sure ifthere is any way to check the board via SSH or something to get a positive as to whetherthe port is working or not? Ihave a coworker that is bringing in a board Monday and we will try the camera and cable on that one. Until then - I haveno idea what to do.
