Wyze cam V2 - Flashed to V2Webcam Firmware
I can see it being picked up and trying to display, but fail.
troubleshooted to see if pi picks it up.
Lsusb:
pi@octopi : /var/log $ lsusb
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Log:
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Feb 4 17:29:57 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -y -d /dev/video10
i: Using V4L2 device.: /dev/video10
i: Frames Per Second.: 10
i: Format............: YUYV
i: JPEG Quality......: 80
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Goodbye...
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10 -y
raspi options: -fps 10
Octopi Latest from Github
Raspberry pi 3B+
