- Serial exceptions when using Pi4 2GB wtih Octoprint 1.5.2
- Webcam issues after every print
Creality Ender 5 Plus Printer running 1.7.1 KF (Marlin Firmware) Some prints pause and then fail and the reported error is Serial Exceptions. Happened since upgrading to 1.5.X Some prints fail faster than others
On a couple of occasions, I have Chrome open on the Octoprint page, and when switch back to it with the web browser I am able to trigger the issue, or atleast thats when the browser updates and I can see the issue reported. Printer sits behind me so I can hear when its stopped ahead of checking the webcam footage, however, when I have refreshed the browser, twice now the print has then paused, and the Serial Exception error has occured.
Web browser is Chrome
Using Webcamd and service restart I can recover the Webcam issue.
Rebooted Pi
Rebooted Printer
Changed USB cable
5V pin removed from cable
Tried running in safe mode and the problem has happened again, and Octoprint is reporting same again.
No it did not. I have downgraded from 1.5.2 to 1.4.2 and then run in safe mode and the problem persists
Complete Logs
Log attached
octoprint (1).log (111.0 KB)
