Camera Model - PS3 Move Eye
What is the problem? - Octoprint says the Webcam server is not running
**What did you already try to solve it? - Tried editing the /boot/octopi.txt
added camera ="auto"
camera_usb_options="-r 640x480 -f 10 -y "
additional_brokenfps_usb_devices=(1415:2000)
Logs (/var/log/webcamd.log
, Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Aug 20 11:47:40 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
MJPG Streamer Version: git rev: 85f89a8c321e799fabb1693c5d133f3fb48ee748
Goodbye...
i: Using V4L2 device.: /dev/video10
i: Frames Per Second.: 10
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
pi@octopi:~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1415:2000 Nam Tai E&E Products Ltd. or OmniVision Technologies, Inc. Sony Playstation Eye
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Additional information about your setup (OctoPrint version, 1.5.2 and Octopi version 0.18.0)
