Pi Cam 2.1 NoIR
The Stream does not start
brand new Instalation
only the steps on the page
no action done to cam, as it was told not needed on the web page (octopi.txt un-touched!)
rpi-eeprom-update.log (292 Bytes)
webcamd.log (2.8 KB)
vcgencmd get_camera
supported=1 detected=1
sudo systemctl status webcamd
webcamd.service - the OctoPi webcam daemon with the user specified config
Active: active (running) since Tue 2021-06-01 11:22:03 CEST; 54s ago
Process: 461 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
Main PID: 485 (mjpg_streamer)
Tasks: 2 (limit: 4915)
ββ485 ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: www-folder-path......: ./www-octopi/
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: HTTP TCP port........: 8080
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: HTTP Listen Address..: 127.0.0.1
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: username:password....: disabled
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: commands.............: disabled
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: starting input plugin input_uvc.so
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: starting output plugin: output_http.so (ID: 00)
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: Can't enable video in first time
Jun 01 11:22:02 KlimaPi3D mjpg_streamer[485]: MJPG-streamer [485]: cleaning up resources allocated by input thread
Jun 01 11:22:03 KlimaPi3D systemd[1]: Started the OctoPi webcam daemon with the user specified config.
