pi cam v1
cam no longer streaming
replaced with a new pi cam v1 thinking it may be the camera.
checked webcamd.log
vcgencmd get_camera
webcamd.log:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices: // when it used to work, it found /dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
// raspi no longer showen in this line
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10 // used to be /dev/video0
/root/bin/webcamd: line 184: printf: 0x: invalid hex number // these 2 lines not
/root/bin/webcamd: line 184: printf: 0x: invalid hex number // present in working log
<13>Feb 2 09:39:59 root: Starting USB webcam // last working log Jan 29 16:41:34
- It seems that you don't have VL805 (Raspberry Pi 4). // this line always, using pi3b+
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10 // was dev/video0
i: Using V4L2 device.: /dev/video10 // was dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported. // working log different from here.
i: init_VideoIn failed
working log did display instead of error:
o: HTTP Listen Address..: 127.0.0.1
o: username:password....: disabled // Octopi password has been set
Goodbye...
OctoPrint 1.8.6
Python 37.3
Octopi 0.18.0
Octoeverywhere 1.11.1
Hi folks,
Hope you can help.. Ive suddenly lost all streaming capability.. Viewing webcamd.log, it seems is no longer picking up the camera as dev/video0, but dev/video10 and with this - throwing errors.
Checking the logs and comparing the last time it was working (29 jan 2023), I have highlighted changes as bold comments. typing "vcgencmd get_camera" returns:
supported=1 detected=0
So, for some reason my pi cam is supported (dev/video0?), but no longer detected.. Though I have used Linux before, Im certainly not a guru..
Any help would be appreciated, as Im not that comfortable running the printer without the camera to keep an eye on it, rendering my printer useless unless Im sat on top of it for several hours - which just isnt practical either..
Kind regards and thanks in advance for any help given..
