OV5647 β https://www.raspberrypi.org/documentation/hardware/camera/
I have the Raspberry Pi Camera Module v1. When I changed camera_raspi_options in /boot/octopi.txt the stream was not reflected, but I was able to tweak the stream using camera_usb_options. Looking at the process it is using input_uvc.so so I think it doesn't recognize my camera.
pi@octopi:~ $ ps -aux | grep streamer
pi 365 3.1 1.5 64016 5936 ? Sl 23:14 0:17 ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 1280x720 -f 30 -d /dev/video0
Could not solve it.
/var/log/webcamd.log
Starting up webcamDaemon...
camera: auto
usb options: -r 1280x720 -f 30
raspi options: -x 1296 -y 972 -fps 10 -quality 95
http options: -w ./www-octopi -n
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Jun 14 23:41:46 pi: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 1280x720 -f 30 -d /dev/video0
MJPG Streamer Version: git rev: ddb69b7b4f114f3c2ca01adf55712792ca8aed43
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 30
i: Format............: JPEG
o: HTTP Listen Address..: (null)
OctoPrint 1.3.11 running on OctoPi 0.16.0
