When connecting to Octopi over the internet streaming from my Pi-cam is incredibly slow. Over the local network it's effectively real time.
If I RDP to a machine on the local network, I can watch via the Pi-cam via RDP over the Internet and it's in real time.
Nothing yet, been trying to figure out the cause of the problem, I wouldn't expect viewing the stream over RDP to be so good in performance if its terrible to stream directly. So I'm stumped.
OctoPrint 1.3.8 running on OctoPi 0.15.1
18 Mb/s DSL down 1.8 MB/s DSL up
The Wifi signal strength is 87% and works great locally... just not remote.
The stream is an MJPG Stream. MJPG doesn't compress the individual frames (whereas RDP for example does a whole ton of optimizations of the transmitted video data), hence it needs a whole lot of bandwidth. The upside of that is that it causes next to no overhead on the Pi.
Long story short: this is expected behaviour. You might have luck re-transcoding the stream if you want to have better performance via a net connection, but you really don't want to do that on the Pi.
