Camera model - standard Pi camera - ribbon connected
What is the problem? - video shows up everywhere except in octoprint browser interface. The web interface just shows a short and empty box under the webcam tab. If I go to the webcam and timelapse config page, and without changint the URL I press the "Test" button, A window opens with visible video (although it's upside down). If I browse to the URL of the webcam directly, video comes up in the browser. The ONLY place video does not show up is in the octproint browser interface itself. This happens on Windows 10, Windows 11, and Linux Mint. Interestingly enough, the video also works properly if I activate the touchui interface, but when I go back to the standard web page, still nothing.
This used to work fine - it has worked for months. I'm not sure when it started failing like this, but I can't remember anything I did that might have caused this.
What did you already try to solve it? - just by turning settings off and on, etc
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Nov 1 21:58:24 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
Octoprint 1.7.2, OctoPi 0.18.0
