octopi.local works perfectly, but if I connect and boot to PI UI, everything works fine until I approach the menu, then on mouseover the screen will switch in and out.
However, if I click on Filemanager, that loads and displays without hitch.
Its like if I go over the Rasberry it sends me one
Different power supplies confirm thats not the issue
OOhps, no
browser.user_agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:90.0) Gecko/20100101 Firefox/90.0 connectivity.connection_check: 1.1.1.1:53 connectivity.connection_ok: true connectivity.enabled: true connectivity.online: true connectivity.resolution_check: octoprint.org connectivity.resolution_ok: true env.hardware.cores: 1 env.hardware.freq: 1000 env.hardware.ram: 386326528 env.os.bits: 32 env.os.id: linux env.os.platform: linux env.plugins.pi_support.model: Raspberry Pi Zero Rev 1.3 env.plugins.pi_support.octopi_version: 0.18.0 env.plugins.pi_support.throttle_state: 0x0 env.python.pip: 20.3.3 env.python.version: 3.7.3 env.python.virtualenv: true octoprint.safe_mode: false octoprint.version: 1.6.1 systeminfo.generator: systemapiWRITE HERE
