I am looking to put a PI and cam together so I can monitor my P1S Bambu a little better than the stock onboard camera.
I want to do streaming, etc...
Can this be done, and what plugins would I need to do this?
Normally the Octoprint system would be looking at GCode to tell when to do a timelapse, etc...
So... Can this be accomplished being the Bambu P1S cannot be connected to a PI.
Yup that works and should work out of the box. No plugins needed.
What works??? Timelapse plug in relies on GCode...
Oh I missed the timelapse part
Which camera are you going to use?
A usb one connected to a Rapberry PI w Touchscreen... Haven't purchased the setup yet, and that's why I am looking into this first...
Would a VIRTUAL printer in Octoprint work??? And just load the same GCode to the virtual???
hmm Interesting Idea
I guess that should work - I see no reason why not
foosel
October 10, 2023, 2:57pm
7
The virtual printer is for development. It will not "print" with the same speed as your closed source printer, so the likelihood of this working out is slim.
I honestly don't understand using OctoPrint only as a timelapse recorder, there are existing solutions for that with way less overhead that are easily found online.
I haven't found anything else... Plus I have 2 other Octopi existing so I am trying to make it so I can see all my stuff in one place not 3...
Don't care about exact timelapse... just want remote viewing, and streaming as well as a timelapse... I am not trying to reinvent wheel
I would look into something like motioneyeOS or similar.
