Hi, Here is my problem with octopi 0.17.0
Thanks a lot for your help, I must say I know very little about linux, I followed a tutorial to install Octopi and then the graphic interface (I had to ggogle to use vi to put a log at the end...
Thanks for any help and for your patience !
Stephane.
Camera model Raspberry Pi v2.1
What is the problem? On Rasperry Pi 2 Model B v1.1, I have the Error :
"Failed to start OctoPi webcam daemon with the user specified in config."
What did you already try to solve it? All I could... Everything (including the pi camera) was working after initial installation of Octopi 0.17.0,
but since I installed the following the control cannot display the video any more :
sudo apt-get update
sudo apt-get dist-upgrade
$ sudo reboot
Then the Graphic Server :
$ sudo apt-get install xserver-xorg
Then the desktop :
$ sudo apt-get install raspberrypi-ui-mods
Then Session manager :
sudo apt-get install lightdm
sudo reboot
At least install of Starting Navigator :
sudo apt-get install chromium-browser --yes
sudo reboot
syslog
login as: pi
pi@192.168.0.24's password:
Linux octopi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Apr 4 18:32:06 2020 from 192.168.0.31
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
Access OctoPrint from a web browser on your network by navigating to any of:
http://octopi.local
http://192.168.0.24
http://[2a01:e0a:a:a240:da13:5cd0:e91d:5b43]
https is also available, with a self-signed certificate.
OctoPrint version : 1.3.12
OctoPi version : 0.17.0
pi@octopi:~ cd /var/log
pi@octopi:/var/log ls
alternatives.log daemon.log.1 kern.log syslog
apt debug kern.log.1 syslog.1
auth.log debug.1 lastlog user.log
auth.log.1 dpkg.log lightdm user.log.1
boot.log faillog messages wtmp
bootstrap.log fontconfig.log messages.1 Xorg.0.log
btmp haproxy.log private Xorg.0.log.old
daemon.log haproxy.log.1 regenerate_ssh_host_keys.log
pi@octopi:/var/log $ vi syslog
Apr 5 00:00:55 octopi rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="304" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
Apr 5 00:00:55 octopi systemd[1]: logrotate.service: Succeeded.
Apr 5 00:00:55 octopi systemd[1]: Started Rotate log files.
Apr 5 00:00:56 octopi systemd[1]: man-db.service: Succeeded.
Apr 5 00:00:56 octopi systemd[1]: Started Daily man-db regeneration.
Apr 5 00:08:08 octopi systemd[1]: Created slice User Slice of UID 1000.
Apr 5 00:08:08 octopi systemd[1]: Starting User Runtime Directory /run/user/1000...
Apr 5 00:08:09 octopi systemd[1]: Started User Runtime Directory /run/user/1000.
Apr 5 00:08:09 octopi systemd[1]: Starting User Manager for UID 1000...
Apr 5 00:08:09 octopi systemd[1407]: Listening on GnuPG network certificate management daemon.
Apr 5 00:08:09 octopi systemd[1407]: Starting D-Bus User Message Bus Socket.
Apr 5 00:08:09 octopi systemd[1407]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Apr 5 00:08:09 octopi systemd[1407]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Apr 5 00:08:09 octopi systemd[1407]: Reached target Paths.
Apr 5 00:08:09 octopi systemd[1407]: Reached target Timers.
"syslog" [readonly] 26 lines, 898964 characters
