Try to get Pi zero W worked with my ender3
I understand pi zero w is not recommended due to its CPU resource issue. But I am still interested in trying it.
I downloaded the latest 0.17 version octoprint. It boots up no problem and I got wifi and octoprint web interface working. But when I connected ender3 via usb. It does not recognize the ender3. dmesg did not print any line. It just looks like a died port or cable. I swap usb cables and another ender3 printer, it does the same thing.
Octoprint log
2019-12-27 16:04:47,036 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "pp7_ender3"' for _http._tcp
2019-12-27 16:04:47,206 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "pp7_ender3"' for _octoprint._tcp
2019-12-27 16:04:47,276 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "pp7_ender3" for SSDP
2019-12-27 16:04:47,607 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-12-27 16:04:47,828 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-12-27 16:05:07,080 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-12-27 16:05:07,957 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-12-27 16:05:10,044 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-12-27 16:05:10,054 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-12-27 16:05:10,062 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-12-27 16:05:12,025 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.32/'}
2019-12-27 16:05:12,132 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 56}
2019-12-27 16:05:13,924 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.16', 'ram': 387194880, 'octopi_version': '0.17.0', 'version': u'1.3.12', 'pip': '19.3.1', 'cores': 1, 'freq': 1000.0, 'pi_model': 'Raspberry Pi Zero W Rev 1.1', 'os': 'linux'}
2019-12-27 16:05:15,505 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'plugins': u''}
2019-12-27 16:05:28,320 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.19
2019-12-27 16:05:29,751 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.1.19
2019-12-27 16:05:29,902 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.1.19
2019-12-27 16:06:48,318 - octoprint.server.preemptive_cache - INFO - ... done in 96.29s
2019-12-27 16:15:22,816 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-12-27 16:15:22,928 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-12-27 16:15:24,548 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect_port, payload: {'commerror_text': 'Failed to autodetect serial port, please set it manually.'}
2019-12-27 16:15:25,704 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-12-27 16:15:25,861 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-12-27 16:15:27,459 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect_port, payload: {'commerror_text': 'Failed to autodetect serial port, please set it manually.'}
Serial log
2019-12-27 16:15:22,805 - Changing monitoring state from "Offline" to "Detecting serial port"
2019-12-27 16:15:22,917 - Serial port list: []
2019-12-27 16:15:22,924 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-12-27 16:15:22,955 - Failed to autodetect serial port, please set it manually.
2019-12-27 16:15:25,695 - Changing monitoring state from "Offline" to "Detecting serial port"
2019-12-27 16:15:25,837 - Serial port list: []
2019-12-27 16:15:25,856 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-12-27 16:15:25,898 - Failed to autodetect serial port, please set it manually.
Ender3 firmware creality 1.1.6
OctoPi 0.17
Octoprint Version 1.3.12
Thank you very much for the help!
