Every few hours my octopi is unreachable via the octopi browser infterface (using both ip and local addresses). The unit also stopped in the middle of a print once.
I discovered that I had two regions commented in the wifi settings by mistake. I was already installing a new flash of octopi on a different SD card so I double checked that my wifi settings were correct on the new SD card and moved forward. This time the unit seemed to work for a longer period, but the next day I came back and the ocotpi was once again unresponsive.
Have you tried running in safe_mode?
Yes.
Did running in safe_mode solve the problem?
No. The unit was unresponsive after a couple hours.
Complete_Logs
octoprint.log, serial.log or output on terminal tab at a minimum, browser error console if UI issue ... no_logs, no support! Not log excerpts, complete_logs.)
octoprint log (the latest portion, it won't all fit)
2021-01-14 19:59:21,845 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2021-01-14 19:59:21,861 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-01-14 19:59:21,887 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-01-14 19:59:23,049 - octoprint.server - INFO - Shutting down intermediary server...
2021-01-14 19:59:23,527 - octoprint.server - INFO - Intermediary server shut down
2021-01-14 19:59:23,530 - octoprint.events - INFO - Processing startup event, this is our first event
2021-01-14 19:59:23,531 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2021-01-14 19:59:23,544 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-01-14 19:59:23,545 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-01-14 19:59:23,552 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-01-14 19:59:23,628 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-01-14 19:59:23,648 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from ttps://plugins.octoprint.org/update_check_overlay.json
2021-01-14 19:59:25,532 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {u'throttled_mask': 0, u'throttled_voltage_now': False, u'throttled_voltage_past': False, u'throttled_overheat_now': False, u'throttled_now': False, u'throttled_past': False, u'throttled_overheat_past': False}
2021-01-14 19:59:25,850 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-01-14 19:59:25,876 - octoprint.server - INFO - Trying to connect to configured serial port None
2021-01-14 19:59:25,942 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-14 19:59:25,953 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-01-14 19:59:25,954 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-01-14 19:59:25,973 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2021-01-14 19:59:25,973 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-01-14 19:59:25,976 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-01-14 19:59:25,996 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-01-14 19:59:26,000 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-14 19:59:26,791 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2021-01-14 19:59:27,611 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-01-14 19:59:27,628 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2021-01-14 19:59:27,682 - octoprint.server - INFO - Listening on ttp://127.0.0.1:5000
2021-01-14 19:59:27,684 - octoprint.server - INFO - Server started successfully in safe_mode as requested from config, removing flag
2021-01-14 19:59:27,777 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-01-14 19:59:27,938 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-14 19:59:28,185 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-01-14 19:59:28,221 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.113
2021-01-14 19:59:28,653 - octoprint.server.util.flask - INFO - Passively logging in user enderpi from ::ffff:192.168.2.113
2021-01-14 19:59:28,657 - octoprint.access.users - INFO - Logged in user: enderpi
2021-01-14 19:59:28,803 - octoprint.server.util.sockjs - INFO - User enderpi logged in on the socket from client ::ffff:192.168.2.113
2021-01-14 19:59:29,417 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-01-14 19:59:29,419 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-01-14 19:59:29,419 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-01-14 19:59:29,581 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 5.0GB. That is considered sufficient for updating.
2021-01-14 19:59:30,509 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-01-14 19:59:30,975 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'ttp://192.168.2.34/'}
2021-01-14 19:59:31,580 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 12}
2021-01-14 19:59:32,279 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 917016576, u'octopi_version': u'0.17.0', u'version': u'1.5.2', u'plugins': u'', u'pip': '19.3.1', u'cores': 4, u'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', u'bits': 32}
2021-01-14 19:59:33,180 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 917016576, u'octopi_version': u'0.17.0', u'version': u'1.5.2', u'pip': '19.3.1', u'cores': 4, u'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', u'bits': 32}
2021-01-14 19:59:35,090 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin TH3D U1.R2.A2"
2021-01-14 19:59:36,600 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': None, u'firmware_name': u'Marlin TH3D U1.R2.A2'}
2021-01-14 19:59:43,739 - octoprint.server.preemptive_cache - INFO - ... done in 12.76s
2021-01-14 20:00:02,395 - octoprint.server.util.flask - INFO - Passively logging in user enderpi from ::ffff:192.168.2.113
2021-01-14 20:00:02,398 - octoprint.access.users - INFO - Logged in user: enderpi
2021-01-14 20:00:02,573 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.113
2021-01-14 20:00:04,016 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.113
2021-01-14 20:00:04,106 - octoprint.server.util.flask - INFO - Passively logging in user enderpi from ::ffff:192.168.2.113
2021-01-14 20:00:04,108 - octoprint.access.users - INFO - Logged in user: enderpi
2021-01-14 20:00:07,613 - octoprint.server.util.sockjs - INFO - User enderpi logged in on the socket from client ::ffff:192.168.2.113
2021-01-14 20:03:13,571 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3831, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 6455, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2021-01-14 20:03:13,608 - octoprint.util.comm - ERROR - Please see ttps://faq.octoprint.org/serialerror for possible reasons of this.
2021-01-14 20:03:13,619 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Offline (Error: Serial_Exception: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831)"
2021-01-14 20:03:13,637 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-01-14 20:14:18,781 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-14 20:14:31,510 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 912}
2021-01-14 20:29:18,784 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-14 20:29:31,552 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1812}
2021-01-14 20:33:19,403 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.113
2021-01-14 20:44:18,787 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-14 20:44:31,707 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 2712}
2021-01-14 20:59:18,790 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-14 20:59:31,495 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 3612}
2021-01-14 20:57:30,772 - octoprint.startup - INFO - ******************************************************************************
2021-01-14 20:57:30,776 - octoprint.startup - INFO - Starting OctoPrint 1.5.2
2021-01-14 20:57:30,777 - octoprint.startup - INFO - ******************************************************************************
2021-01-14 20:57:36,575 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2021-01-14 20:57:36,576 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2021-01-14 20:57:36,577 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2021-01-14 20:57:36,578 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprintorg is working
2021-01-14 21:02:23,489 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2021-01-14 21:02:23,624 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-01-14 21:02:26,188 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 36 hook handlers
2021-01-14 21:02:26,476 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-01-14 21:02:26,552 - octoprint.server - INFO - Intermediary server started
2021-01-14 21:02:26,591 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2021-01-14 21:02:27,090 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2021-01-14 21:02:27,095 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2021-01-14 21:02:27,096 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2021-01-14 21:02:27,098 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2021-01-14 21:02:27,100 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2021-01-14 21:02:27,101 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2021-01-14 21:02:27,104 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2021-01-14 21:02:27,105 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2021-01-14 21:02:27,107 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2021-01-14 21:02:27,109 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2021-01-14 21:02:27,111 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2021-01-14 21:02:27,113 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2021-01-14 21:02:27,115 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2021-01-14 21:02:27,117 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2021-01-14 21:02:27,118 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2021-01-14 21:02:27,120 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2021-01-14 21:02:27,337 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-01-14 21:02:28,916 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-01-14 21:02:30,000 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2021-01-14 21:02:30,002 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-01-14 21:02:30,003 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-01-14 21:02:30,038 - octoprint.plugin.core - INFO - Initialized 18 plugin implementation(s)
2021-01-14 21:02:30,059 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Preheat Button (0.5.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
2021-01-14 21:02:30,101 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.3.1
| version: 2.7.16
2021-01-14 21:02:30,114 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-01-14 21:02:30,136 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-01-14 21:02:31,512 - octoprint.server - INFO - Shutting down intermediary server...
2021-01-14 21:02:31,889 - octoprint.server - INFO - Intermediary server shut down
2021-01-14 21:02:31,893 - octoprint.events - INFO - Processing startup event, this is our first event
2021-01-14 21:02:31,896 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2021-01-14 21:02:31,909 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from ttps://plugins.octoprint.org/update_check_overlay.json
2021-01-14 21:02:31,921 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-01-14 21:02:31,925 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-01-14 21:02:32,059 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-01-14 21:02:32,003 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-01-14 21:02:33,915 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-01-14 21:02:34,117 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {u'throttled_mask': 0, u'throttled_voltage_now': False, u'throttled_voltage_past': False, u'throttled_overheat_now': False, u'throttled_now': False, u'throttled_past': False, u'throttled_overheat_past': False}
2021-01-14 21:02:34,193 - octoprint.plugins.softwareupdate - ERROR - Could not fetch check overlay from ttps://plugins.octoprint.org/update_check_overlay.json: 502 Server Error: Bad Gateway for url: ttps://plugins.octoprint.org/update_check_overlay.json
2021-01-14 21:02:34,217 - octoprint.server - INFO - Trying to connect to configured serial port None
2021-01-14 21:02:34,284 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-14 21:02:34,293 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-01-14 21:02:34,296 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-01-14 21:02:34,313 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-01-14 21:02:34,314 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-01-14 21:02:34,317 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-01-14 21:02:34,339 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-01-14 21:02:35,144 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2021-01-14 21:02:35,614 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {u'commerror_text': u'No more candidates to test, and no working port/baudrate combination detected.'}
2021-01-14 21:02:35,964 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-01-14 21:02:35,972 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2021-01-14 21:02:36,003 - octoprint.server - INFO - Listening on ttp://127.0.0.1:5000
2021-01-14 21:02:36,049 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1610670754012 (::ffff:192.168.2.113) 35.62ms
2021-01-14 21:02:36,128 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1610670756515 (::ffff:192.168.2.113) 71.20ms
2021-01-14 21:02:36,211 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-01-14 21:02:36,683 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670757886 (::ffff:192.168.2.113) 149.93ms
2021-01-14 21:02:37,456 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-01-14 21:02:37,793 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-01-14 21:02:37,794 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-01-14 21:02:37,794 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-01-14 21:02:37,945 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-01-14 21:02:38,413 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-01-14 21:02:38,542 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-01-14 21:02:38,545 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1610670758854 (::ffff:192.168.2.113) 1404.41ms
2021-01-14 21:02:38,551 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 5.0GB. That is considered sufficient for updating.
2021-01-14 21:02:38,552 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-01-14 21:02:38,587 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670759414 (::ffff:192.168.2.113) 33.06ms
2021-01-14 21:02:39,075 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'ttp://192.168.2.34/'}
2021-01-14 21:02:39,733 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670761334 (::ffff:192.168.2.113) 28.79ms
2021-01-14 21:02:39,846 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 13}
2021-01-14 21:02:40,629 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 917016576, u'octopi_version': u'0.17.0', u'version': u'1.5.2', u'plugins': u'preheat:0.5.1', u'pip': '19.3.1', u'cores': 4, u'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', u'bits': 32}
2021-01-14 21:02:40,857 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670762479 (::ffff:192.168.2.113) 29.60ms
2021-01-14 21:02:41,363 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 917016576, u'octopi_version': u'0.17.0', u'version': u'1.5.2', u'pip': '19.3.1', u'cores': 4, u'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', u'bits': 32}
2021-01-14 21:02:43,302 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670763603 (::ffff:192.168.2.113) 654.78ms
2021-01-14 21:02:44,534 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670766048 (::ffff:192.168.2.113) 28.13ms
2021-01-14 21:02:46,734 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670767282 (::ffff:192.168.2.113) 1093.34ms
2021-01-14 21:02:47,945 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670769478 (::ffff:192.168.2.113) 128.41ms
2021-01-14 21:02:49,074 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670770692 (::ffff:192.168.2.113) 34.28ms
2021-01-14 21:02:50,603 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670771823 (::ffff:192.168.2.113) 179.62ms
2021-01-14 21:02:51,750 - tornado.access - WARNING - 404 GET /cached.gif?_=1610670773353 (::ffff:192.168.2.113) 26.16ms
2021-01-14 21:02:52,347 - octoprint.server.preemptive_cache - INFO - ... done in 13.27s
2021-01-14 21:02:53,151 - octoprint.server.views - INFO - Found path / in cache (key: ui:_default:ttp://192.168.2.34/:en), signaling as cached
2021-01-14 21:02:53,245 - octoprint.server.util.flask - INFO - Passively logging in user enderpi from ::ffff:192.168.2.113
2021-01-14 21:02:53,248 - octoprint.access.users - INFO - Logged in user: enderpi
2021-01-14 21:02:54,966 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.113
2021-01-14 21:02:55,074 - octoprint.server.util.flask - INFO - Passively logging in user enderpi from ::ffff:192.168.2.113
2021-01-14 21:02:55,075 - octoprint.access.users - INFO - Logged in user: enderpi
2021-01-14 21:02:58,535 - octoprint.server.util.sockjs - INFO - User enderpi logged in on the socket from client ::ffff:192.168.2.113
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.141 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
connectivity.resolution_check: octoprintorg
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 917016576
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
Summary
This text will be hidden
