I decided to move from my Pi Zero to a Pi4 for my Octoprint server. I used Etcher to create a fresh install from the latest image, then edited the octopi-wpa-supplicant.txt just like I did for the zero. When I boot the Pi4 it just settles into a mode where the onboard green LED flashes 4 long flashes then 4 short. Looking at https://www.raspberrypi.org/documentation/configuration/led_blink_warnings.md I discovered this equates to "Unsupported board type". Per my understanding, this board is supported with Octoprint.
Burned the image to the SD card again
Downloaded the image again
Looked for log files on SD card that might indicate fault
Searched the internet
Complete Logs
I am unable to establish an SSH connection as the machine is not booting.
The Raspberry Pi 4 comes in different models. The 1, 2 and 4 GB models are supported out of the box by octopi 0.17; the 8 GB model is not. See this thread: Octoprint on a pi4 8gb
I have a Pi 4 2GB and successfully installed the Octopi 0.17 and got it working fine, I then did an apt update and then it would not reboot, all I was getting was the 4 long and 4 short flashes ?
The 4 long 4 short indicates unsupported board - from the table in the above guide
Long flashes Short flashes Status
0 3 Generic failure to boot
0 4 start*.elf not found
0 7 Kernel image not found
0 8 SDRAM failure
0 9 Insufficient SDRAM
0 10 In HALT state
2 1 Partition not FAT
2 2 Failed to read from partition
2 3 Extended partition not FAT
2 4 File signature/hash mismatch - Pi 4
4 4 Unsupported board type
4 5 Fatal firmware error
4 6 Power failure type A
4 7 Power failure type B
You might have ended up with some kind of corruption there, although I would have thought that might have ended up with a different code.
You might be better off creating a new topic, since it is not the same problem as the above topic
