Server will not run
tired to reset the pi manually and via SSH
Logs (octoprint.log, serial.log or output on terminal tab, ...)
File "/home/pi/oprint/bin/octoprint", line 6, in
from pkg_resources import load_entry_point
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 3019, in
@_call_aside
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 3003, in _call_aside
f(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 3032, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 655, in _build_master
ws.require(requires)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 963, in require
needed = self.resolve(parse_requirements(requirements))
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/init.py", line 849, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'typing<4,>=3.6.6' distribution was not found and is required by OctoPrint
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
octoprint version: 1.3.11
octopi version :0.15.1
I beleive i will need to reimage, should i do this or is there another method to fix this via SSH?
Try a manual reinstall via SSH
