I tried to activate the slicer plugin that was installed on my octopi server ; immediately after, octopi restarted, all my plugins / setups disappeared and I cannot install anything anymore.
Plugins I have on my octopi: at least octoeverywhere, calibration tools + a few other I cannot remember as of now.
I got the error
2024-05-09 09:23:49,331 ! Traceback (most recent call last):
2024-05-09 09:23:49,332 ! File "<string>", line 1, in <module>
2024-05-09 09:23:49,332 ! File "/tmp/pip-req-build-z_kgw25b/setup.py", line 110, in <module>
2024-05-09 09:23:49,333 ! setup(**setup_parameters)
2024-05-09 09:23:49,334 ! File "/home/pi/oprint/lib/python3.7/site-packages/setuptools/__init__.py", line 152, in setup
2024-05-09 09:23:49,335 ! _install_setup_requires(attrs)
2024-05-09 09:23:49,336 ! File "/home/pi/oprint/lib/python3.7/site-packages/setuptools/__init__.py", line 142, in _install_setup_requires
2024-05-09 09:23:49,337 ! dist = MinimalDistribution(attrs)
2024-05-09 09:23:49,338 ! File "/home/pi/oprint/lib/python3.7/site-packages/setuptools/__init__.py", line 134, in __init__
2024-05-09 09:23:49,339 ! distutils.core.Distribution.__init__(self, filtered)
2024-05-09 09:23:49,340 ! File "/home/pi/oprint/lib/python3.7/site-packages/setuptools/dist.py", line 421, in __init__
2024-05-09 09:23:49,341 ! for ep in pkg_resources.iter_entry_points('distutils.setup_keywords'):
2024-05-09 09:23:49,341 ! File "/home/pi/oprint/lib/python3.7/site-packages/pkg_resources/__init__.py", line 656, in <genexpr>
2024-05-09 09:23:49,342 ! for entry in dist.get_entry_map(group).values()
2024-05-09 09:23:49,343 ! File "/home/pi/oprint/lib/python3.7/site-packages/pkg_resources/__init__.py", line 2802, in get_entry_map
2024-05-09 09:23:49,344 ! self._get_metadata('entry_points.txt'), self
2024-05-09 09:23:49,345 ! File "/home/pi/oprint/lib/python3.7/site-packages/pkg_resources/__init__.py", line 2504, in parse_map
2024-05-09 09:23:49,346 ! maps[group] = cls.parse_group(group, lines, dist)
2024-05-09 09:23:49,347 ! File "/home/pi/oprint/lib/python3.7/site-packages/pkg_resources/__init__.py", line 2479, in parse_group
2024-05-09 09:23:49,348 ! raise ValueError("Invalid group name", group)
2024-05-09 09:23:49,348 ! ValueError: ('Invalid group name', 'ocdoprint.pl}gin')
I tried to find the faulty file containing the string 'ocdoprint.pl}gin' which sounds suspicious
This is ./oprint/lib/python3.7/site-packages/OctoPrint_PiSupport-2023.10.10.dist-info/entry_points.txt which contains
[ocdoprint.pl}gin]
pi_suptort = octoprint_pi_support
It looks like this file has been corrupted ; I tried to "fix" it but it did not help (just now I have different errors while trying to install any extension and I did not recover my previous extensions)
I just get different error messages now
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
Yes
octoprint-systeminfo-20240509093825.zip (55.6 KB)
