Hello, I'm an experienced user by now, had OctoPi on my old printer for years. I just set up another one for the Voron 2.4 I just built and have this strange problem with plugins:
If I use the Plugin manager to install a new plugin, it shows the install popup with the usual "Installing plugin "x" from https://github.com/y/z/archive/master.zip..." and then hangs indefinitely.
If I try to install the same plugin via SSH, it works, but I get the "WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='codeload.github.com', port=443): Read timed out. (read timeout=15)")': /jneilliii/OctoPrint-AutoTerminalInput/zip/master" message at the beginning.
OctoPrint version : 1.5.3
OctoPi version : 0.18.0
Pi 4, 2GB RAM
Klipper
Everything else seems to work. This is a recurring problem, going on for days now. Currently I have camera disabled (still in the mail
), the rest is stock. Anybody has any ideas? The logs for plugin manager and software update are empty, main log has this to say (from startup to page reload after stuck install popup):
2021-02-28 07:56:32,352 - octoprint.startup - INFO - ******************************************************************************
2021-02-28 07:56:32,354 - octoprint.startup - INFO - Starting OctoPrint 1.5.3
2021-02-28 07:56:32,355 - octoprint.startup - INFO - ******************************************************************************
2021-02-28 07:56:32,644 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2021-02-28 07:56:37,753 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2021-02-28 07:56:37,753 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2021-02-28 07:56:37,754 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2021-02-28 07:57:12,531 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2021-02-28 07:57:12,577 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-02-28 07:57:13,039 - octoprint.plugin.core - INFO - Plugin Virtual Printer is disabled.
2021-02-28 07:57:13,343 - octoprint.plugin.core - INFO - Plugin Firmware Check (2021.2.4) is disabled.
2021-02-28 07:57:13,493 - octoprint.plugin.core - INFO - Found 28 plugin(s) providing 26 mixin implementations, 45 hook handlers
2021-02-28 07:57:13,598 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-02-28 07:57:13,605 - octoprint.server - INFO - Intermediary server started
2021-02-28 07:57:13,620 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2021-02-28 07:57:13,854 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2021-02-28 07:57:13,856 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2021-02-28 07:57:13,856 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2021-02-28 07:57:13,857 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2021-02-28 07:57:13,857 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2021-02-28 07:57:13,857 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
2021-02-28 07:57:13,858 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2021-02-28 07:57:13,858 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2021-02-28 07:57:13,858 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2021-02-28 07:57:13,859 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2021-02-28 07:57:13,859 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2021-02-28 07:57:13,859 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_install'), Need(method='role', value='plugin_pluginmanager_manage')")
2021-02-28 07:57:13,859 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2021-02-28 07:57:13,860 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2021-02-28 07:57:13,860 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
2021-02-28 07:57:14,431 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-02-28 07:57:14,943 - octoprint.util.pip - INFO - Version of pip is 21.0.1
2021-02-28 07:57:14,944 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-02-28 07:57:14,946 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-02-28 07:57:15,033 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-02-28 07:57:15,078 - octoprint.plugins.excluderegion - INFO - Logging mode set to 'octoprint'
2021-02-28 07:57:15,078 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=True, mayShrinkRegionsWhilePrinting=True, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding", "type": "ExcludedGcode"}, 'M117': {"gcode": "M117", "mode": "last", "description": "Suppress display messages while excluding and output the last message encountered when exiting the excluded area", "type": "ExcludedGcode"}, 'M204': {"gcode": "M204", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area", "type": "ExcludedGcode"}, 'M205': {"gcode": "M205", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area", "type": "ExcludedGcode"}, 'M73': {"gcode": "M73", "mode": "merge", "description": "Suppress progress updates while excluding and output the most recent progress values encountered when exiting the excluded area", "type": "ExcludedGcode"}}, atCommandActions={'ExcludeRegion': [{"command": "ExcludeRegion", "parameterPattern": "^\\s*(enable|on)(\\s|$)", "action": "enable_exclusion", "description": "Default action to enable exclusion", "type": "AtCommandAction"}, {"command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|$)", "action": "disable_exclusion", "description": "Default action to disable exclusion", "type": "AtCommandAction"}]}
2021-02-28 07:57:15,108 - octoprint.plugin.core - INFO - Initialized 26 plugin implementation(s)
2021-02-28 07:57:15,121 - octoprint.plugin.core - INFO - 28 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Autoscroll (0.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_autoscroll
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| DisplayLayerProgress Plugin (1.25.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_DisplayLayerProgress
| DisplayProgress (0.1.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_displayprogress
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Exclude Region (0.3.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_excluderegion
| File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| !Firmware Check (2021.2.4) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| GcodeEditor (0.2.12) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_GcodeEditor
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Navbar Temperature Plugin (0.14) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_navbartemp
| OctoKlipper (0.3.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_klipper
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Preheat Button (0.6.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_preheat
| Pushbullet (0.1.14) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_octobullet
| RequestSpinner (0.2.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_requestspinner
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| TouchUI (0.3.17) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_touchui
| !Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2021-02-28 07:57:15,145 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 2008989696
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.4
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 21.0.1
| version: 3.7.3
| virtualenv: /home/pi/oprint
2021-02-28 07:57:15,156 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-02-28 07:57:15,177 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-02-28 07:57:15,612 - octoprint.server - INFO - Shutting down intermediary server...
2021-02-28 07:57:15,736 - octoprint.server - INFO - Intermediary server shut down
2021-02-28 07:57:15,737 - octoprint.events - INFO - Processing startup event, this is our first event
2021-02-28 07:57:15,738 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2021-02-28 07:57:15,738 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-02-28 07:57:15,742 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-02-28 07:57:15,745 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-02-28 07:57:15,746 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2021-02-28 07:57:15,797 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-02-28 07:57:15,995 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 0, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2021-02-28 07:57:16,557 - octoprint.server - INFO - Trying to connect to configured serial port /tmp/printer
2021-02-28 07:57:16,648 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-28 07:57:16,649 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /tmp/printer@115200, /tmp/printer@250000, /tmp/printer@230400, /tmp/printer@57600, /tmp/printer@38400, /tmp/printer@19200, /tmp/printer@9600
2021-02-28 07:57:16,649 - octoprint.util.comm - INFO - Serial detection: Trying port /tmp/printer, baudrate 115200
2021-02-28 07:57:16,649 - octoprint.util.comm - INFO - Connecting to port /tmp/printer, baudrate 115200
2021-02-28 07:57:16,661 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-02-28 07:57:16,663 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-02-28 07:57:16,665 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-02-28 07:57:16,666 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-02-28 07:57:16,674 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-28 07:57:16,677 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-02-28 07:57:16,683 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-28 07:57:16,707 - octoprint.util.comm - INFO - Printer reports firmware name "Klipper"
2021-02-28 07:57:16,707 - octoprint.util.comm - INFO - Detected Klipper firmware, enabling relevant features for issue free communication
2021-02-28 07:57:17,199 - octoprint.plugins.softwareupdate - DEBUG - Looks like we are online
2021-02-28 07:57:17,506 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Voron"._http._tcp.local.' for _http._tcp.local.
2021-02-28 07:57:18,313 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Voron"._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-02-28 07:57:18,338 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Voron" for SSDP
2021-02-28 07:57:18,368 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2021-02-28 07:57:18,418 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-02-28 07:57:18,997 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-02-28 07:57:19,003 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-02-28 07:57:19,020 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-02-28 07:57:19,092 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 52.2GB. That is considered sufficient for updating.
2021-02-28 07:57:19,337 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-02-28 07:57:22,363 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {'firmware_name': 'Klipper', 'printer_port': '/tmp/printer', 'printer_baudrate': 0}
2021-02-28 07:57:25,355 - octoprint.plugins.softwareupdate - ERROR - Could not check GcodeEditor for updates
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connection.py", line 421, in connect
tls_in_tls=tls_in_tls,
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 429, in ssl_wrap_socket
sock, context, tls_in_tls, server_hostname=server_hostname
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 472, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.7/ssl.py", line 412, in wrap_socket
session=session
File "/usr/lib/python3.7/ssl.py", line 853, in _create
self.do_handshake()
File "/usr/lib/python3.7/ssl.py", line 1117, in do_handshake
self._sslobj.do_handshake()
socket.timeout: _ssl.c:1039: The handshake operation timed out
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 756, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 706, in urlopen
chunked=chunked,
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 385, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=conn.timeout)
File "/home/pi/oprint/lib/python3.7/site-packages/urllib3/connectionpool.py", line 337, in _raise_timeout
self, url, "Read timed out. (read timeout=%s)" % timeout_value
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='api.github.com', port=443): Read timed out. (read timeout=3.05)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 1496, in _get_current_version
target, check, online=online, credentials=credentials
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/version_checks/github_release.py", line 348, in get_latest
apikey=apikey,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/version_checks/github_release.py", line 122, in _get_latest_release
RELEASE_URL.format(user=user, repo=repo), timeout=(3.05, 30), headers=headers
File "/home/pi/oprint/lib/python3.7/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='api.github.com', port=443): Read timed out. (read timeout=3.05)
2021-02-28 07:57:25,469 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-02-28 07:57:25,605 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 12}
2021-02-28 07:57:25,645 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:x
2021-02-28 07:57:25,699 - octoprint.server.util.flask - INFO - Passively logging in user x from ::ffff:x
2021-02-28 07:57:25,699 - octoprint.access.users - INFO - Logged in user: x
2021-02-28 07:57:25,779 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.5.3', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '21.0.1', 'cores': 4, 'freq': 1500.0, 'ram': 2008989696, 'pi_model': 'Raspberry Pi 4 Model B Rev 1.4', 'octopi_version': '0.18.0', 'plugins': 'touchui:0.3.17,preheat:0.6.0,requestspinner:0.2.0,octobullet:0.1.14,navbartemp:0.14,gcodeeditor:0.2.12,excluderegion:0.3.0,displayprogress:0.1.3,autoscroll:0.0.3,klipper:0.3.2,displaylayerprogress:1.25.4'}
2021-02-28 07:57:26,274 - octoprint.plugins.octobullet - INFO - Connected to PushBullet
2021-02-28 07:57:26,444 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://voron.local/', 'path': '/', 'query_string': 'l10n=en'}
2021-02-28 07:57:28,454 - octoprint.plugins.softwareupdate - DEBUG - Looks like we are online
