Octoprint Server won't start.
No idea how to resolve this. Can I re-compile the plugin manager? Please can someone advise how I do this? Or do I need to re-install?
2020-07-14 07:05:18,911 - octoprint.startup - CRITICAL - Could not initialize plugin manager: Bad magic number in /usr/lib/python2.7/distutils/command/init.pyc
2020-07-14 07:05:18,917 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
OctoPrint version: 1.4.0
OctoPi version: 0.15.0PE
caveat: I know nothing about the internals of OctoPrint
but: I do know about python
files ending in .pyc are compiled python files
they are derived from the source file ending in .py
so what I would do (YMMV) is
- check that /usr/lib/python2.7/distutils/command/__init.py__ exists
- rename /usr/lib/python2.7/distutils/command/__init__.pyc to /usr/lib/python2.7/distutils/command/__init__OLD.pyc
- try again
what SHOULD happen is that it recompiles xxx.py to make xxx.pyc
Thanks for your prompt response. I tried this, but now the log says:
2020-07-14 07:59:05,901 - octoprint.startup - CRITICAL - Could not initialize plugin manager: No module named command.install
2020-07-14 07:59:05,908 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
It looks like your filesystem has gotten corrupted. This can happen for example when the OS is not properly shut down before the power is disconnected.
Backup the .octoprint folder and burn a new image. Then restore the .octoprint folder and hope none of the files in the .octoprint folder were affected by the filesystem corruption.
As with any computer system with files you consider valuable, doing regular backups is always a good idea. OctoPrint has a backup command and you can download the resulting file somewhere safe. I have a USB SD card reader for creating new images for my RPi and I can plug the same device into the RPi itself and make a clone of the entire OS.
There is no direct upgrade. You have to install 0.17 direct to the SD card. You can do a backup in octoprint, copy the backup file to a thumb drive, I stall octopi 0.17 and restore the backup you saved
