Plugin Manager not working (self installed Octoprint on Linux)
#1
I am not able to install plugins. I followed this guide here https://discourse.octoprint.org/t/setting-up-octoprint-on-a-raspberry-pi-running-raspbian/2337 to install Octoprint on a Ubuntu 18.04 LTS Server. I have a own user "octoprint" for running Ocotprint and my /etc/default/octoprint is:
# Configuration for /etc/init.d/octoprint`
# The init.d script will only run if this variable non-empty.
OCTOPRINT_USER=octoprint
# base directory to use
BASEDIR=/home/octoprint
# configuration file to use
#CONFIGFILE=/home/pi/.octoprint/config.yaml
# On what port to run daemon, default is 5000
PORT=5000
# Path to the OctoPrint executable, you need to set this to match your installation!
#DAEMON=/opt/OctoPrint/venv/bin/octoprint
DAEMON=/usr/local/bin/octoprint
# What arguments to pass to octoprint, usually no need to touch this
DAEMON_ARGS="--port=$PORT"
# Umask of files octoprint generates, Change this to 000 if running octoprint as its own, separate user
#UMASK=022
UMASK=000
# Process priority, 0 here will result in a priority 20 process.
# -2 ensures Octoprint has a slight priority over user processes.
NICELEVEL=-2
# Should we run at startup?
START=yes
The Pluginmanager_console_log says:
2018-08-20 16:52:48,961   /usr/bin/python -m pip install linkkk_needed_to_be_removed_because_new_user_here --no-cache-dir --user
2018-08-20 16:52:49,971 > Collecting link...
2018-08-20 16:52:51,299 > Downloading link...
2018-08-20 16:52:51,299 > Collecting OctoPrint (from OctoPrint-EEprom-Marlin-Printrbot==0.1.0)
2018-08-20 16:52:51,300 ! Could not find a version that satisfies the requirement OctoPrint (from OctoPrint-EEprom-Marlin-Printrbot==0.1.0) (from versions: )
2018-08-20 16:52:51,300 ! No matching distribution found for OctoPrint (from OctoPrint-EEprom-Marlin-Printrbot==0.1.0)
2018-08-20 16:55:06,261   /usr/bin/python -m pip install link... p --no-cache-dir --user
2018-08-20 16:55:07,275 > Collecting link...
2018-08-20 16:55:08,571 > Downloading link...
2018-08-20 16:55:08,571 > Collecting OctoPrint (from OctoPrint-Pushover==0.2.1)
2018-08-20 16:55:08,571 ! Could not find a version that satisfies the requirement OctoPrint (from OctoPrint-Pushover==0.2.1) (from versions: )
2018-08-20 16:55:08,571 ! No matching distribution found for OctoPrint (from OctoPrint-Pushover==0.2.1)
I am pretty sure I messed up with some user rights, but I don't know where to look, the error log is giving me no hint.
#2
Hi, I've still got that problem - but I came closer - I can manually update via shell when using the sudo command (sudo pip install https...).
So there is a problem with the rights - could anyone give me a hint where to look / what to change?
Thank you!
#3
Are you using any of the venv-related commands? Python apps these days carve out their own virtual environments so that their own version of packages don't clash with other apps.
Read this thread for more info.
#4
Hi, Developer of the pushover plugin here.
Does it work ? Maybe I can help ?
