When trying to set settings for my plugin they somehow aren't properly saved & don't appear in the settings (localhost/api/settings). Upon checking for the settings-values I just set, it returns None
I've tried replicating the code from a working plugin I use "DeleteAfterPrint" - upon installing, the settings are created as they should.
The code in my plugin;
# coding=utf-8
from __future__ import absolute_import
import octoprint.plugin
import octoprint.settings
import os
class PrinterHubTestPlugin(octoprint.plugin.SettingsPlugin,
octoprint.plugin.StartupPlugin,
octoprint.plugin.EventHandlerPlugin,
octoprint.filemanager.storage.StorageInterface):
# #~~ StartupPlugin mixin
def on_after_startup(self):
self._settings.set_boolean(["test1"], True)
self._settings.set_boolean(["test2"], False)
self._settings.set(["test3"], "test_string")
self._settings.save()
Logs
https://pastebin.com/raw/mmFF8Rse
- Octoprint version: 1.3.12 running on OctoPi 0.15.1
