Plugins installed when accessing Octoprint through the IP address the RPi is on from Wifi, are not showing as installed when accessing Octoprint through the wired IP address. So if i log into Octoprint from the WIFI ip address all my plugin are there. If i access through the wired ethernet, my plugins aren't installed.
I logged out and back into Octoprint. Cannot reboot until current print is complete
Octoprint version-1.38
Octopi version -0.15.0
Did you try forcing a full asset reload in the browser (depending on browser/OS: CMD-SHIFT-R or CTRL-SHIFT-R)? Are you sure it's the same OctoPrint instance? Did you reboot after installing the plugins to begin with?
I know it was the correct instance of octoprint since I had a print running and was able to see the print on the camera, under the controls tab. The other printers were not running.
I found it odd that I could go from one to the other, see the same video, but one had the plugins and one did not.
I will end up doing a reboot of the computer and the RPI and try again. I may just turn off wifi and run only on Ethernet, since I get better streaming when wired.
As a former I.T. guy, I'd have to wonder if your Internet router treats the wired versus wi-fi networks differently. It's entirely possible that the router has looser rules on the wi-fi side of things, for some strange reason.
(At the code academy where I work, some guy who doesn't have an I.T. background has programmed the local router and it's a mess.)
There is a strange feature/bug aspect of browser local storage which can manifest itself in the way you are describing.
Local storage (a place where a programmer can store a JSON object/database-like thing) is stored using three pieces of information: protocol + app/website + the IP address which was used to reach it.
Scenario:
- Under the control of your wi-fi session's IP address, something saves information in local storage
- You turn off wi-fi, plug in an RJ-45 Ethernet cable and refresh your browser to find that it now no longer has access to that earlier local storage
Rebooting the PC didn’t help.
I tried from my tablet and it was good. So it’s a computer issue not an Octoprint issue.
I’ll figure it out and fix it, now that it’s the computer and not Octoprint or router.
Clear your cache? Probably a caching issue.
