The printer starts moving the Z axis up and down randomly and the x axis the same, while extruding.
I can print the same gcode just fine, but on follow on prints it sometimes has this issue.
I've created a video of the behaviour https://photos.app.goo.gl/eucdGzQSgGDF21Gk6
Removing plugins installed recently
2020-05-06 17:24:21,945 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 7266}
2020-05-06 17:27:40,774 - octoprint.util.comm - INFO - Finished in 7160.495 s.
2020-05-06 17:27:40,788 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2020-05-06 17:27:40,846 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: Fusebox_Lid.gcode, owner: jamie
2020-05-06 17:27:40,975 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2020-05-06 17:27:42,390 - octoprint.plugins.tracking - INFO - Sent tracking event print_done, payload: {'origin': u'local', 'file': 'bc2dc6c3fa80e47cf74043f3e0932505becd9243', u'elapsed': 7160}
2020-05-06 17:29:40,388 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-05-06 17:29:40,477 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Fusebox_Lid.gcode, owner: jamie, user: jamie
2020-05-06 17:29:40,536 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-06 17:29:40,609 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-05-06 17:29:42,142 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': u'local', 'file': 'bc2dc6c3fa80e47cf74043f3e0932505becd9243'}
2020-05-06 17:33:01,584 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.3
2020-05-06 17:34:48,360 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.3
2020-05-06 17:34:49,165 - octoprint.server.util.flask - INFO - Passively logging in user jamie from ::ffff:192.168.1.3
2020-05-06 17:34:49,181 - octoprint.access.users - INFO - Logged in user: jamie
2020-05-06 17:34:49,562 - octoprint.server.util.sockjs - INFO - User jamie logged in on the socket from client ::ffff:192.168.1.3
2020-05-06 17:38:18,551 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 17:39:21,068 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 8166}
2020-05-06 17:46:42,578 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.3
2020-05-06 17:53:18,571 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 17:54:21,216 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 9066}
2020-05-06 18:02:56,533 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-05-06 18:08:18,590 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 18:23:18,601 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 18:38:18,614 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 18:48:04,004 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-05-06 18:48:04,257 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-05-06 18:48:20,506 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-05-06 18:53:18,628 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 18:54:25,937 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 12666}
2020-05-06 19:03:07,079 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-05-06 19:08:18,643 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 19:18:08,269 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-05-06 19:18:08,512 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-05-06 19:18:27,162 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-05-06 19:23:18,665 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 19:24:21,236 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 14466}
2020-05-06 19:27:02,397 - octoprint.util.comm - INFO - Finished in 7042.012 s.
2020-05-06 19:27:02,411 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2020-05-06 19:27:02,469 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: Fusebox_Lid.gcode, owner: jamie
2020-05-06 19:27:02,675 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2020-05-06 19:27:03,995 - octoprint.plugins.tracking - INFO - Sent tracking event print_done, payload: {'origin': u'local', 'file': 'bc2dc6c3fa80e47cf74043f3e0932505becd9243', u'elapsed': 7042}
2020-05-06 19:33:11,345 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-05-06 19:38:18,677 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 19:44:59,052 - octoprint.server.util.flask - INFO - Passively logging in user jamie from ::ffff:192.168.1.3
2020-05-06 19:44:59,065 - octoprint.access.users - INFO - Logged in user: jamie
2020-05-06 19:45:03,895 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.3
2020-05-06 19:45:04,773 - octoprint.server.util.flask - INFO - Passively logging in user jamie from ::ffff:192.168.1.3
2020-05-06 19:45:04,786 - octoprint.access.users - INFO - Logged in user: jamie
2020-05-06 19:45:14,789 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-05-06 19:45:14,999 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-05-06 19:45:16,948 - octoprint.server.util.sockjs - INFO - User jamie logged in on the socket from client ::ffff:192.168.1.3
2020-05-06 19:45:29,025 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-05-06 19:45:29,156 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Fusebox_Lid.gcode, owner: jamie, user: jamie
2020-05-06 19:45:29,221 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-06 19:45:29,341 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-05-06 19:45:31,371 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': u'local', 'file': 'bc2dc6c3fa80e47cf74043f3e0932505becd9243'}
2020-05-06 19:45:35,955 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-05-06 19:53:18,690 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-06 19:24:46,348 - octoprint.startup - INFO - ******************************************************************************
2020-05-06 19:24:46,360 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-05-06 19:24:46,363 - octoprint.startup - INFO - ******************************************************************************
2020-05-06 19:24:50,975 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-05-06 19:24:51,842 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2020-05-06 19:24:52,163 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-05-06 19:55:08,199 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 32 hook handlers
2020-05-06 19:55:09,753 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-05-06 19:55:09,967 - octoprint.server - INFO - Intermediary server started
2020-05-06 19:55:09,981 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-05-06 19:55:11,048 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 32 hook handlers
2020-05-06 19:55:11,321 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-05-06 19:55:15,374 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-05-06 19:55:15,410 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-05-06 19:55:15,421 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-05-06 19:55:15,433 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-05-06 19:55:15,445 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-05-06 19:55:15,458 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-05-06 19:55:15,471 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-05-06 19:55:15,482 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-05-06 19:55:15,495 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-05-06 19:55:15,507 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-05-06 19:55:15,518 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-05-06 19:55:15,529 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-05-06 19:55:15,540 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-05-06 19:55:16,486 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-05-06 19:55:23,858 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-05-06 19:55:30,851 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-05-06 19:55:30,866 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-05-06 19:55:30,875 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-05-06 19:55:30,907 - octoprint.plugin.core - INFO - Initialized 18 plugin implementation(s)
2020-05-06 19:55:31,011 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
| Continuous Print (1.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/continuousprint
| Firmware Updater (1.7.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| TouchUI (0.3.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_touchui
2020-05-06 19:55:31,129 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 387194880
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi Model B Plus Rev 1.2
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
OctoPrint 1.4.0 running on OctoPi 0.17.0
