I have an Anycubic Predator (Delta) running on an Duet 2 wifi board with a Duet Smart effector, the printer works very well now but to be able to work with colors I bought a Palette 2 S Pro and installed OctoPrint (latest version) on a Raspberry B+ because the Palette 2 S Pro has to work with OctoPrint.
OctoPrint is running on the pi via wifi and I can connect to the Predator (Duet) with OctoPrint, hotend and bed temp works, homing also, but when I do some test moves I get next error
"Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: G0 / G1: target position not reachable from current position"
When I dive into the internet I don't see any setups that use OctoPrint in combination with Duet 2 wifi, so I wonder if this will be a good marriage at all !!
The question is, can this work? or should I give this up and return the Palette 2 S Pro and spend my hard earned money elsewhere?
Btw, I'm a noob in the field of programming and quite new to the 3D printer field, so rocket science isn't really my thing
Greetings and thanks in advance,
Mario
the Netherlands
