i get error " Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)" when i connect Octoprint
i added serial port /dev/ttyAMA* but still same issue
2020-06-18 17:41:14,980 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:41:15,029 - Serial port list: []
2020-06-18 17:41:15,030 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:41:15,037 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:47:48,218 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:47:48,357 - Serial port list: []
2020-06-18 17:47:48,359 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:47:48,363 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:48:17,953 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:48:18,027 - Serial port list: []
2020-06-18 17:48:18,028 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:48:18,035 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:49:32,971 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:49:33,048 - Serial port list: []
2020-06-18 17:49:33,049 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:49:33,054 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:49:37,692 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:49:37,839 - Serial port list: []
2020-06-18 17:49:37,842 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:49:37,859 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:50:42,473 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:50:42,549 - Serial port list: []
2020-06-18 17:50:42,551 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:50:42,556 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:51:14,280 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:51:14,356 - Serial port list: []
2020-06-18 17:51:14,358 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:51:14,362 - Failed to autodetect serial port, please set it manually.
2020-06-18 17:51:35,400 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 17:51:35,480 - Serial port list: []
2020-06-18 17:51:35,480 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-06-18 17:51:35,486 - Failed to autodetect serial port, please set it manually.
2020-06-18 18:06:25,636 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 18:06:25,837 - Serial port list: ['/dev/ttyAMA0']
2020-06-18 18:06:25,839 - Connecting to: /dev/ttyAMA0
2020-06-18 18:06:25,844 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-06-18 18:06:25,851 - Connected to: Serial<id=0x67ddceb0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:06:25,855 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:06:25,873 - Send: N0 M110 N0*125
2020-06-18 18:06:25,973 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:06:25,980 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:06:25,985 - Connection closed, closing down monitor
2020-06-18 18:06:36,459 - Connecting to: /dev/ttyAMA0
2020-06-18 18:06:36,489 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:06:36,494 - Connected to: Serial<id=0x67ddcb30, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:06:36,495 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:06:36,518 - Send: N0 M110 N0*125
2020-06-18 18:06:36,590 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:06:36,595 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:06:36,604 - Connection closed, closing down monitor
2020-06-18 18:07:15,780 - Connecting to: /dev/ttyAMA0
2020-06-18 18:07:15,804 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:07:15,812 - Connected to: Serial<id=0x67dac490, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:07:15,815 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:07:15,895 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:07:15,899 - Send: N0 M110 N0*125
2020-06-18 18:07:15,901 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:07:15,921 - Connection closed, closing down monitor
2020-06-18 18:08:26,797 - Connecting to: /dev/ttyAMA0
2020-06-18 18:08:26,820 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:08:26,827 - Connected to: Serial<id=0x67f357d0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:08:26,830 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:08:26,850 - Send: N0 M110 N0*125
2020-06-18 18:08:26,920 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:08:26,935 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:08:26,941 - Connection closed, closing down monitor
2020-06-18 18:08:38,085 - Connecting to: /dev/ttyAMA0
2020-06-18 18:08:38,111 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:08:38,126 - Connected to: Serial<id=0x688c40d0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:08:38,131 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:08:38,145 - Send: N0 M110 N0*125
2020-06-18 18:08:38,215 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:08:38,218 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:08:38,231 - Connection closed, closing down monitor
2020-06-18 18:08:46,524 - Connecting to: /dev/ttyAMA0
2020-06-18 18:08:46,554 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:08:46,563 - Connected to: Serial<id=0x688ee550, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:08:46,567 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:08:46,584 - Send: N0 M110 N0*125
2020-06-18 18:08:46,662 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:08:46,666 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:08:46,682 - Connection closed, closing down monitor
2020-06-18 18:08:54,460 - Connecting to: /dev/ttyAMA0
2020-06-18 18:08:54,484 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:08:54,492 - Connected to: Serial<id=0x689886f0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:08:54,495 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:08:54,592 - Send: N0 M110 N0*125
2020-06-18 18:08:54,592 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:08:54,597 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:08:54,612 - Connection closed, closing down monitor
2020-06-18 18:09:23,006 - Connecting to: /dev/ttyAMA0
2020-06-18 18:09:23,030 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:09:23,037 - Connected to: Serial<id=0x68881b30, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:09:23,040 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:09:23,075 - Send: N0 M110 N0*125
2020-06-18 18:09:23,152 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:09:23,157 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:09:23,168 - Connection closed, closing down monitor
2020-06-18 18:09:45,226 - Connecting to: /dev/ttyAMA0
2020-06-18 18:09:45,249 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:09:45,254 - Connected to: Serial<id=0x688c49d0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:09:45,257 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:09:45,280 - Send: N0 M110 N0*125
2020-06-18 18:09:45,364 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:09:45,372 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:09:45,382 - Connection closed, closing down monitor
2020-06-18 18:09:52,695 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 18:09:52,772 - Serial port list: ['/dev/ttyAMA0']
2020-06-18 18:09:52,773 - Connecting to: /dev/ttyAMA0
2020-06-18 18:09:52,777 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-06-18 18:09:52,784 - Connected to: Serial<id=0x68988af0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:09:52,785 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:09:52,801 - Send: N0 M110 N0*125
2020-06-18 18:09:52,880 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:09:52,884 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:09:52,894 - Connection closed, closing down monitor
2020-06-18 18:09:52,904 - Closing down send loop
2020-06-18 18:09:56,805 - Connecting to: /dev/ttyAMA0
2020-06-18 18:09:56,826 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:09:56,832 - Connected to: Serial<id=0x688c4850, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:09:56,838 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:09:56,930 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:09:56,932 - Send: N0 M110 N0*125
2020-06-18 18:09:56,938 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:09:56,948 - Connection closed, closing down monitor
2020-06-18 18:10:00,239 - Connecting to: /dev/ttyAMA0
2020-06-18 18:10:00,263 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:10:00,267 - Connected to: Serial<id=0x6883a430, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:10:00,270 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:10:00,283 - Send: N0 M110 N0*125
2020-06-18 18:10:00,367 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:10:00,383 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:10:00,385 - Closing down send loop
2020-06-18 18:10:00,395 - Connection closed, closing down monitor
2020-06-18 18:11:05,641 - Connecting to: /dev/ttyAMA0
2020-06-18 18:11:05,664 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:11:05,675 - Connected to: Serial<id=0x6897da10, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:11:05,676 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:11:05,689 - Send: N0 M110 N0*125
2020-06-18 18:11:05,770 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:11:05,775 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:11:05,783 - Connection closed, closing down monitor
2020-06-18 18:11:29,130 - Connecting to: /dev/ttyAMA0
2020-06-18 18:11:29,153 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:11:29,159 - Connected to: Serial<id=0x67d90bb0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:11:29,161 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:11:29,173 - Send: N0 M110 N0*125
2020-06-18 18:11:29,252 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:11:29,260 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:11:29,272 - Connection closed, closing down monitor
2020-06-18 18:14:54,213 - Connecting to: /dev/ttyAMA0
2020-06-18 18:14:54,237 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:14:54,245 - Connected to: Serial<id=0x68922b10, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:14:54,247 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:14:54,260 - Send: N0 M110 N0*125
2020-06-18 18:14:54,346 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:14:54,359 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:14:54,372 - Connection closed, closing down monitor
2020-06-18 18:15:05,809 - Connecting to: /dev/ttyAMA0
2020-06-18 18:15:05,832 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:15:05,839 - Connected to: Serial<id=0x6897da10, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:15:05,840 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:15:05,860 - Send: N0 M110 N0*125
2020-06-18 18:15:05,939 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:15:05,944 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:15:05,954 - Connection closed, closing down monitor
2020-06-18 18:15:09,955 - Connecting to: /dev/ttyAMA0
2020-06-18 18:15:09,985 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:15:09,991 - Connected to: Serial<id=0x688c4550, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:15:09,995 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:15:10,010 - Send: N0 M110 N0*125
2020-06-18 18:15:10,093 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:15:10,109 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:15:10,117 - Connection closed, closing down monitor
2020-06-18 18:15:52,993 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-18 18:15:53,069 - Serial port list: ['/dev/ttyAMA0']
2020-06-18 18:15:53,070 - Connecting to: /dev/ttyAMA0
2020-06-18 18:15:53,074 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-06-18 18:15:53,080 - Connected to: Serial<id=0x68a2ffb0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:15:53,085 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:15:53,173 - Send: N0 M110 N0*125
2020-06-18 18:15:53,258 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:15:53,294 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:15:53,339 - Connection closed, closing down monitor
2020-06-18 18:16:02,488 - Connecting to: /dev/ttyAMA0
2020-06-18 18:16:02,519 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:16:02,527 - Connected to: Serial<id=0x67ddc7f0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:16:02,530 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:16:02,546 - Send: N0 M110 N0*125
2020-06-18 18:16:02,623 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:16:02,626 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:16:02,637 - Connection closed, closing down monitor
2020-06-18 18:23:25,811 - Connecting to: /dev/ttyAMA0
2020-06-18 18:23:25,835 - Changing monitoring state from "Offline" to "Opening serial port"
2020-06-18 18:23:25,841 - Connected to: Serial<id=0x68862e50, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-18 18:23:25,842 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-18 18:23:25,860 - Send: N0 M110 N0*125
2020-06-18 18:23:25,942 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823
2020-06-18 18:23:25,958 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2823)"
2020-06-18 18:23:25,970 - Connection closed, closing down monitor
i have a predator printer and SKR 1.4 turbo installed , and Raspberry PI 3B+
