My CR10-V3 (with BL Touch installed) cancels Prints during printing for no reason.
This is not the first time, and i had it on several sliced gcodes.
Next time i start the print it (will fail again on another Position) or the Printer will Finish the print. But i dient changed anything.
i tryed nothing to solve it (cause im not that in with IT...)
No Safe Mode tried.
If i start the print again, or another gcode, no Problems occur.
Complete Logs
Printer: Creality CR10-V2
Octoprint Version 1.5.2
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.1 Safari/605.1.15
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 916779008
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.2
printer.firmware: Marlin Creality 3D
Here are the Log Files.
I cant upload the Code due to restrictions.
octoprint.log (197.9 KB)
serial.log (172.7 KB)
