Hello,
I have discovered a problem today. I have created a G-code file with Cura. Then I have this G-code file from my PC to Octoprint via wifi.
After that I started the print. In the process, I noticed that the print head did not move but conveyed the filament to the outside. I therefore had to abort the print.
When I copied the same file directly to the SD card of the printer and then started the print again, the print process started normally.
Why did this not work with the 1st procedure?
Please in future open these topic in the 'Get Help' subcategory. For now, I have moved it and can you fill in this template:
Complete Logs
