I am having a problem where I click print and the print just starts I know there are two others but they just ended and have turned dead so wanted to start it again.
I have tried some g-code something like G-- T0 190C to preheat the nozzle in the g-code and it didn't work not sure whats happened seems more like a octoprint thing.
Here is my log: octoprint.log (75.1 KB) I hope it works please say if it doesn't.
I am using the latest firmware, Anycubic i3 Mega-S, Raspberry Pi Camera V2, Raspberry pi 3B and I am using a list of plugins like navbar temp, simple emergency stop, bed level thing, thingiverse tab, full screen webcam, octolapse, polarCloud and I think that's it, please help want to get back to printing.
There made a smaller version of the masks as some friends were asking for smaller ones for their smaller heads. But just won't heat up when I click print, via octoprint.
So your print starts with a cold hotend?
Everything moving and the extruder skipping?
If that's the case your firmware is missing the PREVENT_COLD_EXTRUSION setting.
Here a wiki page with all information you need to check if it's enabled and how to enable it if it isn't.
I would use something between 170 - 180 Β°C.
That's no solution for your problem but you should check it
I am using Anycubics Offical Firmware so I dont think theyd missing somthing like that and it was working before so not like its just going to forgot a line of firmware
Apologies, but if you'd seen what printer vendors have missed, broken, forgotten in their firmware and how broken some of them ship their own products, you'd probably never again sleep well.
