Latest octoprint installed and running a new raspberry pi 3b and new SD card on the raspberry. Setup is fine and webcam functions properly. Pi is connected to a CR-10S printer USB port. On startup all coms are fine and temps are read real time correctly. Printer is 'operational'. Slice a calibration cube in cura and pass it to printer via octoprint web interface.. Print starts and after 200 odd bytes are sent in the job the job is hung. Bed and nozzle temps don't budge. I have tried two different usb cables (one brand new) Comms are set 115200 and to /dev/ttyUSB0 port.
Ideas? I must be missing something but I don't know what. Printer is fully functional on SD card prints.
terminal output below:
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x72d9a930, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0125
Recv: start
Send: N0 M110 N0125
Recv: echo: External Reset
Recv: Marlin
Recv: echo: Last Updated: 2015-12-01 12:00 | Author: (none, default config)
Recv: Compiled: Jul 21 2017
Recv: echo: Free Memory: 3154 PlannerBufferBytes: 1232
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E93.00
Recv: echo:Maximum feedrates (mm/s):
Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00
Recv: echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X1000 Y1000 Z100 E5000
Recv: echo:Accelerations: P=printing, R=retract and T=travel
Recv: echo: M204 P500.00 R500.00 T1000.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
Recv: echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:Material heatup parameters:
Recv: echo: M145 M0 H185 B45 F0
Recv: echo: M145 M1 H240 B110 F0
Recv: echo:PID settings:
Recv: echo: M301 P22.20 I1.08 D114.00 C100.00 L20
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D3.00
Recv: echo: M200 D0
Recv: echo:SD init fail
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Send: N0 M110 N0125
Recv: ok
Send: N1 M11539
Recv: FIRMWARE_NAME:Marlin 1.1.0 From Archive SOURCE_CODE_URL:http:// ... PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: ok
Send: M21
Recv: ok
Send: M105
Recv: ok T:19.2 /0.0 B:19.5 /0.0 T0:19.2 /0.0 @:0 B@:0
Send: M105
Recv: ok T:19.2 /0.0 B:19.3 /0.0 T0:19.2 /0.0 @:0 B@:0
Changing monitoring state from "Operational" to "Printing"
Send: N0 M110 N0125
Recv: ok
Send: N1 M140 S5081
Recv: ok
Send: N2 M10537
Recv: ok T:19.1 /0.0 B:19.5 /50.0 T0:19.1 /0.0 @:0 B@:0
Send: N3 M190 S5094
Recv: T:19.30 E:0 B:19.7
Recv: T:19.10 E:0 B:19.3
Recv: T:19.22 E:0 B:19.6
Recv: T:18.87 E:0 B:19.4
Recv: T:19.26 E:0 B:19.5
Recv: T:19.10 E:0 B:19.6
Recv: T:18.91 E:0 B:19.5
Recv: T:19.37 E:0 B:19.4
Recv: T:19.22 E:0 B:19.7
Recv: T:19.18 E:0 B:19.6
Recv: T:19.10 E:0 B:19.4
Recv: T:19.41 E:0 B:19.8
Recv: T:18.98 E:0 B:19.4
Recv: T:19.10 E:0 B:19.5
Recv: T:19.02 E:0 B:19.7
Recv: T:19.06 E:0 B:19.5
Recv: T:19.18 E:0 B:19.5
Recv: T:19.26 E:0 B:19.7
Recv: T:19.37 E:0 B:19.5
Recv: T:19.06 E:0 B:19.3
Recv: T:19.18 E:0 B:19.8
Recv: T:18.98 E:0 B:19.3
