When starting a new print with 1.3.8 octoprint immediately pauses the print. Log shows Recv: action:pause which did not happen before 1.3.8
no solution yet
OctoPrint 1.3.8 running on OctoPi 0.13.0, Ultimaker 2 with Marlin firmware (see log)
I had to tweek the logs a bit and remove the double backslashes. Otherwise I couldn't post this topic...
Octoprint.log:
2018-04-21 13:08:48,195 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-04-21 13:08:48,227 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2018-04-21 13:08:48,230 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-04-21 13:08:48,235 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:08:49,353 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:08:51,868 - octoprint.util.comm - INFO - Ignoring resend request for line 1 == current line, we haven't sent that yet so the printer got N-1 twice from us, probably due to a timeout
2018-04-21 13:08:51,872 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2018-04-21 13:08:51,875 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:08:51,892 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin Ultimaker2; Sprinter/grbl mashup for gen6"
2018-04-21 13:09:08,723 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Pumpenadapter.gcode
2018-04-21 13:09:08,729 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/Pumpenadapter.gcode
2018-04-21 13:09:12,475 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2018-04-21 13:09:12,481 - octoprint.plugins.detailedprogress - INFO - Printing started. Detailed progress started.
2018-04-21 13:09:12,494 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:09:12,516 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2018-04-21 13:09:12,519 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Pumpenadapter.gcode
2018-04-21 13:09:12,522 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/Pumpenadapter.gcode
2018-04-21 13:09:13,046 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2018-04-21 13:09:17,402 - octoprint.util.comm - INFO - Changing monitoring state from "Paused" to "Cancelling"
2018-04-21 13:09:25,833 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Pumpenadapter.gcode finished, needed 13.31s
2018-04-21 13:09:35,351 - tornado.access - WARNING - 403 GET /api/printerprofiles (127.0.0.1) 21.94ms
2018-04-21 13:09:36,016 - octoprint.server.util.sockjs - INFO - Client connection closed: 172.30.72.159
2018-04-21 13:09:36,839 - octoprint.server.util.sockjs - INFO - New connection from client: 172.30.72.159
2018-04-21 13:09:50,649 - octoprint.server.util.sockjs - INFO - Client connection closed: 172.30.72.159
2018-04-21 13:09:50,735 - tornado.access - WARNING - 403 GET /api/plugin/octopi_support (127.0.0.1) 21.59ms
2018-04-21 13:09:50,760 - tornado.access - WARNING - 403 GET /api/connection (127.0.0.1) 21.05ms
2018-04-21 13:09:50,783 - tornado.access - WARNING - 403 GET /api/printer/command/custom (127.0.0.1) 18.75ms
2018-04-21 13:09:50,806 - tornado.access - WARNING - 403 GET /api/system/commands (127.0.0.1) 19.03ms
2018-04-21 13:09:50,830 - tornado.access - WARNING - 403 GET /api/users (127.0.0.1) 19.20ms
2018-04-21 13:09:50,850 - tornado.access - WARNING - 403 GET /api/plugin/printer_safety_check (127.0.0.1) 16.25ms
2018-04-21 13:09:50,939 - tornado.access - WARNING - 403 GET /api/settings (127.0.0.1) 10.65ms
2018-04-21 13:09:50,952 - tornado.access - WARNING - 403 GET /api/files?recursive=true (127.0.0.1) 10.58ms
2018-04-21 13:09:51,561 - octoprint.server.util.sockjs - INFO - New connection from client: 172.30.72.159
2018-04-21 13:10:13,012 - octoprint.server.api.system - INFO - Performing command for core:restart: sudo service octoprint restart
2018-04-21 13:10:13,194 - octoprint.server - INFO - Shutting down...
2018-04-21 13:10:13,660 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-04-21 13:10:13,673 - octoprint.events - INFO - Event loop shut down
2018-04-21 13:10:13,677 - octoprint.server - INFO - Goodbye!
2018-04-21 13:10:16,282 - octoprint.startup - INFO - ******************************************************************************
2018-04-21 13:10:16,283 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-04-21 13:10:16,283 - octoprint.startup - INFO - ******************************************************************************
2018-04-21 13:10:16,549 - octoprint.startup - INFO - Blacklist processing done
2018-04-21 13:10:16,593 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-04-21 13:10:18,361 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-21 13:10:18,454 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-04-21 13:10:19,068 - octoprint.server - INFO - Intermediary server started
2018-04-21 13:10:19,069 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-04-21 13:10:19,330 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-21 13:10:19,361 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-04-21 13:10:19,845 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-04-21 13:10:19,906 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-04-21 13:10:21,595 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-04-21 13:10:23,241 - octoprint.util.pip - INFO - Version of pip is 8.1.1
2018-04-21 13:10:23,242 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-04-21 13:10:23,243 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-04-21 13:10:23,245 - octoprint.plugin.core - INFO - Initialized 11 plugin implementation(s)
2018-04-21 13:10:23,251 - octoprint.plugin.core - INFO - 11 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| Detailed Progress Plugin (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_detailedprogress
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
2018-04-21 13:10:23,265 - octoprint.environment - INFO - Detected environment is Python 2.7.9 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 901685248
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: 3B
| revision: a02082
| version: 0.13.0
| python:
| pip: 8.1.1
| version: 2.7.9
| virtualenv: /home/pi/oprint
2018-04-21 13:10:23,273 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-04-21 13:10:23,287 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-04-21 13:10:23,459 - octoprint.server - INFO - Shutting down intermediary server...
2018-04-21 13:10:23,611 - octoprint.server - INFO - Intermediary server shut down
2018-04-21 13:10:24,213 - octoprint.events - INFO - Processing startup event, this is our first event
2018-04-21 13:10:24,214 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-04-21 13:10:24,216 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-04-21 13:10:24,225 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-04-21 13:10:24,251 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-04-21 13:10:24,271 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-04-21 13:10:24,276 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-04-21 13:10:24,278 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2018-04-21 13:10:24,347 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-04-21 13:10:24,905 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2018-04-21 13:10:26,175 - octoprint.server.util.sockjs - INFO - New connection from client: 172.30.72.159
2018-04-21 13:10:29,689 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-04-21 13:10:29,693 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-04-21 13:10:29,697 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:10:30,822 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:10:33,337 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2018-04-21 13:10:33,345 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:10:33,375 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin Ultimaker2; Sprinter/grbl mashup for gen6"
2018-04-21 13:10:46,312 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2018-04-21 13:10:46,322 - octoprint.plugins.detailedprogress - INFO - Printing started. Detailed progress started.
2018-04-21 13:10:46,344 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-04-21 13:10:46,406 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2018-04-21 13:10:46,943 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2018-04-21 13:11:02,870 - octoprint.util.comm - INFO - Changing monitoring state from "Paused" to "Printing"
Serial.log:
2018-04-21 13:10:28,989 - Connecting to: /dev/ttyACM0
2018-04-21 13:10:29,686 - Changing monitoring state from "Offline" to "Opening serial port"
2018-04-21 13:10:29,691 - Connected to: Serial<id=0x72f99370, open=True>(port='/dev/ttyACM0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2018-04-21 13:10:29,693 - Changing monitoring state from "Opening serial port" to "Connecting"
2018-04-21 13:10:29,698 - Send: N0 M110 N0125
2018-04-21 13:10:30,815 - Recv: start
2018-04-21 13:10:30,823 - Recv: echo:Marlin 1.0.0
2018-04-21 13:10:30,826 - Send: N0 M110 N0125
2018-04-21 13:10:30,826 - Recv: echo: Last Updated: Sep 3 2016 18:56:13 | Author: Tinker_16.08.2
2018-04-21 13:10:30,828 - Recv: Compiled: Sep 3 2016
2018-04-21 13:10:30,830 - Recv: echo: Free Memory: 2585 PlannerBufferBytes: 1232
2018-04-21 13:10:30,831 - Recv: echo:Stored settings retrieved
2018-04-21 13:10:30,833 - Recv: echo:Steps per unit:
2018-04-21 13:10:30,834 - Recv: echo: M92 X80.00 Y80.00 Z200.00 E492.45
2018-04-21 13:10:30,836 - Recv: echo:Maximum feedrates (mm/s):
2018-04-21 13:10:30,837 - Recv: echo: M203 X300.00 Y300.00 Z40.00 E20.00
2018-04-21 13:10:30,838 - Recv: echo:Maximum Acceleration (mm/s2):
2018-04-21 13:10:30,839 - Recv: echo: M201 X9000 Y9000 Z100 E3000
2018-04-21 13:10:30,841 - Recv: echo:Acceleration: S=acceleration, T=retract acceleration
2018-04-21 13:10:30,842 - Recv: echo: M204 S3000.00 T3000.00
2018-04-21 13:10:30,844 - Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
2018-04-21 13:10:30,845 - Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
2018-04-21 13:10:30,846 - Recv: echo:Home offset (mm):
2018-04-21 13:10:30,847 - Recv: echo: M206 X0.00 Y0.00 Z-17.50
2018-04-21 13:10:30,849 - Recv: echo:PID settings:
2018-04-21 13:10:30,850 - Recv: echo: M301 P36.59 I3.65 D91.72
2018-04-21 13:10:33,324 - Recv: echo:SD init fail
2018-04-21 13:10:33,332 - Recv: ok
2018-04-21 13:10:33,336 - Changing monitoring state from "Connecting" to "Operational"
2018-04-21 13:10:33,350 - Send: N0 M110 N0125
2018-04-21 13:10:33,357 - Recv: echo:Unknown command: ""
2018-04-21 13:10:33,359 - Recv: ok
2018-04-21 13:10:33,361 - Send: N1 M11539
2018-04-21 13:10:33,373 - Recv: FIRMWARE_NAME:Marlin Ultimaker2; Sprinter/grbl mashup for gen6 FIRMWARE_URL:github.com/Ultimaker PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ultimaker EXTRUDER_COUNT:1
2018-04-21 13:10:33,377 - Recv: ok
2018-04-21 13:10:33,381 - Send: M117 IP 172.30.72.102
2018-04-21 13:10:33,386 - Recv: ok
2018-04-21 13:10:38,338 - Send: M105
2018-04-21 13:10:38,347 - Recv: ok T:27.5 /0.0 B:25.0 /0.0 B@:0 @:0
2018-04-21 13:10:43,339 - Send: M105
2018-04-21 13:10:43,352 - Recv: ok T:27.6 /0.0 B:25.1 /0.0 B@:0 @:0
2018-04-21 13:10:46,311 - Changing monitoring state from "Operational" to "Printing"
2018-04-21 13:10:46,353 - Send: N0 M110 N0125
2018-04-21 13:10:46,363 - Recv: ok
2018-04-21 13:10:46,365 - Send: N1 G9017
2018-04-21 13:10:46,370 - Recv: ok
2018-04-21 13:10:46,373 - Send: N2 M8227
2018-04-21 13:10:46,379 - Recv: ok
2018-04-21 13:10:46,383 - Send: N3 M106 S255102
2018-04-21 13:10:46,387 - Recv: ok
2018-04-21 13:10:46,392 - Send: N4 G4 P500108
2018-04-21 13:10:46,404 - Recv: action:pause
2018-04-21 13:10:46,405 - Pausing on request of the printer...
2018-04-21 13:10:46,405 - Changing monitoring state from "Printing" to "Pausing"
2018-04-21 13:10:46,903 - Recv: action:resume
2018-04-21 13:10:46,904 - Resuming on request of the printer...
2018-04-21 13:10:46,905 - Recv: ok
2018-04-21 13:10:46,908 - Send: N5 M40034
2018-04-21 13:10:46,916 - Recv: ok
2018-04-21 13:10:46,918 - Send: N6 M114*33
2018-04-21 13:10:46,927 - Recv: X:0.00Y:0.00Z:0.00E:0.00 Count X: 0.00Y:0.00Z:0.00E:0.00
2018-04-21 13:10:46,938 - Recv: ok
2018-04-21 13:10:46,942 - Changing monitoring state from "Pausing" to "Paused"
2018-04-21 13:10:48,340 - Send: M105
2018-04-21 13:10:48,349 - Recv: ok T:27.2 /0.0 B:25.1 /0.0 B@:0 @:0
2018-04-21 13:10:53,341 - Send: M105
2018-04-21 13:10:57,192 - Recv: ok T:27.6 /0.0 B:24.9 /0.0 B@:0 @:0
2018-04-21 13:10:58,342 - Send: M105
2018-04-21 13:10:58,352 - Recv: ok T:26.9 /0.0 B:24.9 /0.0 B@:0 @:0
2018-04-21 13:11:00,437 - Disabling serial logging/
