Print outside print area boundry warning after upgrade to OctoPrint 1.11.7
When trying to print a file, I get a popup warning that the print is out of print area. Note specifically indicates that is issue is with the print depth. This happens no matter what the size of the print object. I have been using OctoPrint for years with the same printer/printer config. This warning only appeared after updating to 1.11.7
I tried to print a 10mm diameter ring at the center of the print bed to ensure print is in bounds.
I checked my printer profile to make sure the bed size configuration is correct... it is set to 250mm x 210mm x 210mm.
I simply select print and the item prints fine.
I get a hint in the warning popup that I can disable the print size checking feature, but don't really want to do that.
No. Able to print in spite of the popup warning
N/A
OctoPrint version 1.11.7, Prusa MK3S, firmware, browser is Firefox, Raspberry Pi Trixie, Web browser access from Windows 11
Closing duplicate: https://community.octoprint.org/t/print-outside-print-area-boundry-warning-after-upgrade-to-octoprint-1-11-7-with-systeminfo-bundle/66195/2?u=jneilliii
