I have a printing Problem with my Malyan M180 printer. Normally i print with .x3g files from SD Card sliced by Simplify 3D. That works great, but i want to use Octoprint(octopi) for my Printer.
I already installed the needed Plugins (GPX, ...), the connection to my printer works fine, i can send the .gcode to the printer and it will start to print, but it looks like, Z is not moving down and so the print will be compressed.
If i use the z-down button in control it works fine but move up instead of down ... i also tested when i invert Z in my printer-profile, now moving is correct but for printing it doesn't matter
All the commands are properly send to the printer, exept:
There is a warning during the start code:
2023-03-02 12:49:27,146 - Send: N8 G92 Z-5*120
2023-03-02 12:49:27,154 - Recv: ok
2023-03-02 12:49:27,156 - Recv: // echo: (line 8) warning G92 emulation unable to determine all coordinates to set via x3g:140 set extended position
2023-03-02 12:49:27,157 - Recv: // echo: current position defined as
2023-03-02 12:49:27,157 - Recv: // echo: X:171.41 Y:53.82 Z:-5.00 A:0.00 B:0.00
You mean start printing the file from the SD card in Octoprint. Or do you mean copy the gcode file to the SD card and start it directly from the printer?
I tried the Malyan Marlin FW from the Malyan Homepage, but this does not work (Printer did not work, after updating to original FW the printer works again)
It looks like the printer is moving down f.e. 0,2mm and instandly moving up f.e. 0,2mm, so the print base stands at the same place while printing
