I woke up early, went to check on my print, and the printer was not moving. Still up to temp, fans on, etc.
tried to log on to octoprint server to see what was going on. I got the page saying the server was not running, and it gave a few suggestions on what to try. I could connect to the Pi with putty, and restarted octoprint. Checked the logs, but found that for some reason the serial logging was disabled.
I'm running a Pi3 model B, OctoPi 0.15.1, OctoPrint 1.3.9, a Prusa I3 MK2S
last few lines of the terminal:
Send: M105
Recv: ok T:148.2 /0.0 B:51.4 /0.0 T0:148.2 /0.0 @:0 B@:0
Send: M105
Recv: ok T:143.9 /0.0 B:51.1 /0.0 T0:143.9 /0.0 @:0 B@:0
Send: M105
Recv: ok T:139.3 /0.0 B:50.8 /0.0 T0:139.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:135.5 /0.0 B:50.4 /0.0 T0:135.5 /0.0 @:0 B@:0
Changing monitoring state from "Operational" to "Offline"
Octoprint log:
octoprint.log (123.6 KB)
I'm not really sure what's going on in the octoprint log, I was hoping someone would see a reason for the server shutting down. For now I have switched back to printing from the SD card until I can figure this out. Thanks for any help in this matter.
