Having problems with the print stopping at random points. If I look at the terminal it appears as if GCODE has stopped being sent to the printer. Happens most consistently when performing bed levelling, after which the print will stop, but has happened mid print as well.
Was working fine, then I had this problem which stopped after i updated firmware on the printer, but suddenly it's come back again.
Tried shorter and longer prints
Tried different SD card and reinstalled from scratch
Tried with an without bed levelling
Tried increasing the timeout values, and monitoring the serial output
Logs (octoprint.log, serial.log or output on terminal tab, ...)
(upload://ynKuzGZRLg0GGjgdEtYJyohrpgB.log) [octoprint.log (606.5 KB)|attachment]
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
Prusa I3 Mk 2.5 Firmware 3.7.1
hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
