I am following this cookbook article. I used the Event Manager interface to enter the details, rather than editing the config.yaml file. After doing that, and restarting the server, the config.yaml file contains this:
<snip>
events:
subscriptions:
- command: curl -o /tmp/printDone.jpg "http://localhost:8081/?action=snapshot" &&
mpack -s "Print of {file} finished" /tmp/printDone.jpg ian@pickworth.me.uk
debug: false
enabled: true
event: PrintDone
type: system
mpack -s "Print of {file} failed" /tmp/printDone.jpg ian@pickworth.me.uk
debug: false
enabled: true
event: PrintFailed
type: system
feature:
<snip>
I tested the commands from the command line, and they resulted in an email being sent correctly - with {file} in the title, obviously.
However, when the print ends, this is logged by Octoprint, and no email sent:
2022-10-04 14:14:12,811 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2022-10-04 14:14:12,824 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: Fridge_Shelf_V3_Ridge_Insets_0.6n_0.35mm_PETG_MINI_19m.gcode, owner: pi
2022-10-04 14:14:12,826 - octoprint.events - WARNING - There was an error processing one or more placeholders in the following command: curl -o /tmp/printDone.jpg "http://localhost:8081/?action=snapshot" && mpack -s "Print of {file} finished" /tmp/printDone.jpg ian@pickworth.me.uk
2022-10-04 14:14:12,883 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
Unless I'm missing something, I've followed the cookbook article exactly.
Can anyone help?
I looked up the message in the forums, but all examples I found are of use of curly braces for linux commands - not what is happening here.
No - doesn't seem relevant since no plug in involved
octoprint-systeminfo-20221004145743.zip (20.5 KB)
