Can't conect to printer, otocprint is up-to-date and also the printer (TH3D 2.5)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware,
Serial port list: ['/dev/ttyUSB0']
Connecting to: /dev/ttyUSB0
Using Malyan/Monoprice Connection Fix Plugin to create serial connection
Connected to: Serial<id=0x6de23d30, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Recv: start
Send: N0 M110 N0125
Recv: echo: External Reset
Recv: Marlin TH3D U1.R2.5
Recv:
Recv: echo: Last Updated: | Author: (TH3D)
Recv: echo:Compiled: Nov 9 2018
Recv: echo: Free Memory: 10142 PlannerBufferBytes: 1232
Recv: echo:V55 stored settings retrieved (683 bytes; crc 19)
Recv: echo: G21 ; (mm)
Recv: echo: M149 C ; Units in Celsius
Recv:
Recv: echo:Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E93.00
Recv: echo:Maximum feedrates (units/s):
Recv: echo: M203 X500.00 Y500.00 Z15.00 E50.00
Recv: echo:Maximum Acceleration (units/s2):
Recv: echo: M201 X1000 Y1000 Z100 E5000
Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo: M204 P500.00 R1000.00 T500.00
Recv: echo:Advanced: Q<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv: echo: M205 Q25000 S0.00 T0.00 X10.00 Y10.00 Z0.40 E5.00
Recv: echo:Auto Bed Leveling:
Recv: echo: M420 S0 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P22.20 I1.08 D114.00
Recv: echo:Z-Probe Offset (mm):
Recv: echo: M851 Z0.00
Recv: echo:SD card ok
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Send: N0 M110 N0125
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin TH3D U1.R2.5 SOURCE_CODE_URL: PROTOCOL_VERSION:1.0 MACHINE_TYPE:Shaped 3D EXTRUDER_COUNT:1 UUID:
Recv: ok
Send: M20
Recv: Begin file list
Send: M115
Send: M504
No response from printer after 3 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Operational" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
