Auto-connect on server startup doesn't work
Here is the log from the terminal tab:
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Error"
Unexpected error while connecting to serial port /dev/ttyUSB0, baudrate 115200 from hook default: SerialException: '[Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'' @ comm.py:_open_serial:3779
thanks for your help in advance
