Thanks for your reply.
The Power source issue is fixed.
But the Printer still doesn't heat up befor starting to print.
Serial.log
2020-05-15 15:54:18,257 - Connecting to: /dev/ttyAMA0
2020-05-15 15:54:18,274 - Changing monitoring state from "Offline" to "Opening serial port"
2020-05-15 15:54:18,287 - Connected to: Serial<id=0x6f007b10, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-05-15 15:54:18,292 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-05-15 15:54:48,380 - There was a timeout while trying to connect to the printer
2020-05-15 15:54:48,387 - Changing monitoring state from "Connecting" to "Offline"
2020-05-15 15:54:48,398 - Connection closed, closing down monitor
2020-05-15 15:57:21,436 - Connecting to: /dev/ttyAMA0
2020-05-15 15:57:21,453 - Changing monitoring state from "Offline" to "Opening serial port"
2020-05-15 15:57:21,463 - Connected to: Serial<id=0x6f040db0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-05-15 15:57:21,463 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-05-15 15:57:38,342 - Connection closed, closing down monitor
2020-05-15 15:57:38,347 - Changing monitoring state from "Connecting" to "Offline"
2020-05-15 15:57:43,127 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-05-15 15:57:43,167 - Serial port list: ['/dev/ttyAMA0', u'/dev/ttyS0']
2020-05-15 15:57:43,167 - Trying /dev/ttyAMA0
2020-05-15 15:57:48,505 - Could not connect to or enter programming mode on /dev/ttyAMA0, might not be a printer or just not allow programming mode
2020-05-15 15:57:48,518 - Trying /dev/ttyS0
2020-05-15 15:57:53,851 - Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
2020-05-15 15:57:53,865 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-05-15 15:57:53,873 - Failed to autodetect serial port, please set it manually.
2020-05-15 15:57:58,418 - Connecting to: /dev/ttyAMA0
2020-05-15 15:57:58,435 - Changing monitoring state from "Offline" to "Opening serial port"
2020-05-15 15:57:58,440 - Connected to: Serial<id=0x682f0610, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-05-15 15:57:58,447 - Starting baud rate detection...
2020-05-15 15:57:58,450 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-05-15 15:57:59,458 - Trying baudrate: 115200
2020-05-15 15:57:59,473 - Send: N0 M110 N0*125
2020-05-15 15:57:59,480 - Recv: echo:Unknown command: "e"(2)
2020-05-15 15:57:59,485 - Recv: ok
2020-05-15 15:57:59,491 - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-05-15 15:57:59,514 - Send: N0 M110 N0*125
2020-05-15 15:57:59,526 - Recv: ok
2020-05-15 15:57:59,531 - Recv: ok
2020-05-15 15:57:59,537 - Send: N1 M115*39
2020-05-15 15:57:59,559 - Recv: FIRMWARE_NAME:Prusa-Firmware 3.8.1 based on Marlin FIRMWARE_URL:https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
2020-05-15 15:57:59,570 - Recv: ok
2020-05-15 15:57:59,576 - Send: M21
2020-05-15 15:57:59,589 - Recv: echo:SD card ok
2020-05-15 15:57:59,952 - Recv: ok
2020-05-15 15:57:59,956 - Send: M20
2020-05-15 15:57:59,959 - Recv: Begin file list
2020-05-15 15:58:00,590 - Recv: End file list
2020-05-15 15:58:00,598 - Recv: ok
2020-05-15 15:58:04,492 - Send: M105
2020-05-15 15:58:04,505 - Recv: ok T:40.0 /0.0 B:32.8 /0.0 T0:40.0 /0.0 @:0 B@:0 P:29.3 A:31.9
2020-05-15 15:58:09,494 - Send: M105
2020-05-15 15:58:09,506 - Recv: ok T:39.8 /0.0 B:32.5 /0.0 T0:39.8 /0.0 @:0 B@:0 P:29.3 A:31.9
2020-05-15 15:58:14,496 - Send: M105
2020-05-15 15:58:14,507 - Recv: ok T:39.6 /0.0 B:32.7 /0.0 T0:39.6 /0.0 @:0 B@:0 P:29.3 A:31.9
2020-05-15 15:58:19,497 - Send: M105
2020-05-15 15:58:19,512 - Recv: ok T:39.6 /0.0 B:32.4 /0.0 T0:39.6 /0.0 @:0 B@:0 P:29.4 A:31.9
2020-05-15 15:58:24,015 - Changing monitoring state from "Operational" to "Starting"
2020-05-15 15:58:24,076 - Changing monitoring state from "Starting" to "Printing"
2020-05-15 15:58:24,107 - Send: N0 M110 N0*125
2020-05-15 15:58:24,110 - Recv: ok
2020-05-15 15:58:24,116 - Send: N1 M73 P0 R299*22
2020-05-15 15:58:24,125 - Recv: NORMAL MODE: Percent done: 0; print time remaining in mins: 299
2020-05-15 15:58:24,131 - Recv: SILENT MODE: Percent done: 255; print time remaining in mins: -1
2020-05-15 15:58:24,134 - Recv: ok
2020-05-15 15:58:24,139 - Send: N2 M73 Q0 S302*22
2020-05-15 15:58:24,148 - Recv: NORMAL MODE: Percent done: 0; print time remaining in mins: 299
2020-05-15 15:58:24,153 - Recv: SILENT MODE: Percent done: 0; print time remaining in mins: 302
2020-05-15 15:58:24,155 - Recv: ok
2020-05-15 15:58:24,160 - Send: N3 M201 X1000 Y1000 Z1000 E5000*57
2020-05-15 15:58:24,166 - Recv: ok
2020-05-15 15:58:24,174 - Send: N4 M203 X200 Y200 Z12 E120*8
2020-05-15 15:58:24,180 - Recv: ok
2020-05-15 15:58:24,183 - Send: N5 M204 P1250 R1250 T1250*80
2020-05-15 15:58:24,190 - Recv: ok
2020-05-15 15:58:24,198 - Send: N6 M205 X8.00 Y8.00 Z0.40 E4.50*57
2020-05-15 15:58:24,204 - Recv: ok
2020-05-15 15:58:24,206 - Send: N7 M205 S0 T0*36
2020-05-15 15:58:24,214 - Recv: ok
2020-05-15 15:58:24,220 - Send: N8 M107*45
2020-05-15 15:58:24,224 - Recv: ok
2020-05-15 15:58:24,235 - Send: N9 M862.3 P "MK3S"*13
2020-05-15 15:58:24,239 - Recv: ok
2020-05-15 15:58:24,247 - Send: N10 M862.1 P0.4*91
2020-05-15 15:58:24,251 - Recv: ok
2020-05-15 15:58:24,259 - Send: N11 M115 U3.8.1*89
2020-05-15 15:58:24,263 - Recv: ok
2020-05-15 15:58:24,271 - Send: N12 G90*35
2020-05-15 15:58:24,275 - Recv: ok
2020-05-15 15:58:24,281 - Send: N13 M83*42
2020-05-15 15:58:24,302 - Recv: ok
2020-05-15 15:58:24,314 - Send: N14 G28 W*81
2020-05-15 15:58:24,999 - Recv: tmc2130_home_enter(axes_mask=0x01)
2020-05-15 15:58:25,697 - Recv: 0 step=61 mscnt= 984
2020-05-15 15:58:25,705 - Recv: tmc2130_goto_step 0 61 2 1000
2020-05-15 15:58:25,757 - Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01
2020-05-15 15:58:25,868 - Recv: tmc2130_home_enter(axes_mask=0x02)
2020-05-15 15:58:26,299 - Recv: echo:busy: processing
2020-05-15 15:58:26,302 - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-05-15 15:58:28,364 - Recv: echo:busy: processing
2020-05-15 15:58:30,327 - Recv: 0 step=18 mscnt= 291
2020-05-15 15:58:30,334 - Recv: tmc2130_goto_step 1 49 2 1000
2020-05-15 15:58:30,423 - Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02
2020-05-15 15:58:30,507 - Recv: echo:busy: processing
2020-05-15 15:58:32,572 - Recv: echo:busy: processing
2020-05-15 15:58:32,710 - Recv: ok
2020-05-15 15:58:32,715 - Send: N15 M400*19
2020-05-15 15:58:32,719 - Recv: ok
2020-05-15 15:58:32,724 - Send: N16 M114*16
2020-05-15 15:58:32,733 - Recv: X:12.00 Y:6.00 Z:0.15 E:0.00 Count X: 11.45 Y:6.59 Z:0.15 E:0.00
2020-05-15 15:58:32,742 - Recv: ok
2020-05-15 15:58:32,748 - Send: N17 M113 S2*87
2020-05-15 15:58:32,756 - Recv: ok
2020-05-15 15:58:32,777 - Send: N18 G80*40
2020-05-15 15:58:34,889 - Recv: echo:busy: processing
2020-05-15 15:58:36,993 - Recv: echo:busy: processing
2020-05-15 15:58:39,062 - Recv: echo:busy: processing
2020-05-15 15:58:41,132 - Recv: echo:busy: processing
2020-05-15 15:58:43,206 - Recv: echo:busy: processing
2020-05-15 15:58:45,298 - Recv: echo:busy: processing
2020-05-15 15:58:46,538 - Recv: ok
2020-05-15 15:58:46,557 - Send: N19 G1 Y-3.0 F1000.0*16
2020-05-15 15:58:46,564 - Recv: ok
2020-05-15 15:58:46,573 - Send: N20 M105*21
2020-05-15 15:58:46,582 - Recv: ok T:38.6 /0.0 B:32.2 /0.0 T0:38.6 /0.0 @:0 B@:0 P:29.2 A:31.8
2020-05-15 15:58:46,594 - Send: N21 G92 E0.0*106
2020-05-15 15:58:46,616 - Recv: ok
2020-05-15 15:58:46,626 - Send: N22 G1 X60.0 F1000.0*1
2020-05-15 15:58:46,653 - Recv: ok
2020-05-15 15:58:46,660 - Send: N23 M400*22
2020-05-15 15:58:48,740 - Recv: echo:busy: processing
2020-05-15 15:58:50,210 - Recv: ok
2020-05-15 15:58:50,222 - Send: N24 M114*17
2020-05-15 15:58:50,231 - Recv: X:60.00 Y:-3.00 Z:0.15 E:0.00 Count X: 59.45 Y:-2.41 Z:0.31 E:0.00
2020-05-15 15:58:50,242 - Recv: ok
2020-05-15 15:58:50,291 - Send: N25 G1 F4020.0*97
2020-05-15 15:58:50,299 - Recv: ok
2020-05-15 15:58:50,314 - Send: N26 G91*37
2020-05-15 15:58:50,324 - Recv: ok
2020-05-15 15:58:50,338 - Send: N27 G1 Z0.500 F6000.000*50
2020-05-15 15:58:50,348 - Recv: ok
2020-05-15 15:58:50,358 - Send: N28 G90*42
2020-05-15 15:58:50,371 - Recv: ok
2020-05-15 15:58:50,378 - Send: N29 G1 X247.500 Y217.770*18
2020-05-15 15:58:50,424 - Recv: ok
2020-05-15 15:58:50,431 - Send: N30 M400*20
2020-05-15 15:58:52,435 - Recv: echo:busy: processing
2020-05-15 15:58:53,325 - Recv: ok
2020-05-15 15:58:53,340 - Send: N31 M114*21
2020-05-15 15:58:53,350 - Recv: X:247.50 Y:211.91 Z:0.65 E:0.00 Count X: 246.96 Y:212.50 Z:1.26 E:0.00
2020-05-15 15:58:53,360 - Recv: ok
2020-05-15 15:58:53,766 - Send: N32 G1 X60.000 Y-3.000*0
2020-05-15 15:58:53,811 - Recv: ok
2020-05-15 15:58:53,814 - Send: N33 M400*23
2020-05-15 15:58:55,903 - Recv: echo:busy: processing
2020-05-15 15:58:56,358 - Recv: echo:enqueing "G1 E-1.000 F2700"
2020-05-15 15:58:56,364 - Recv: echo:enqueing "G1 Z10.652 F800.000"
2020-05-15 15:58:56,370 - Recv: echo:enqueing "CRASH_DETECTEDX"
2020-05-15 15:58:56,375 - Recv: echo: cold extrusion prevented
2020-05-15 15:58:57,220 - Recv: tmc2130_home_enter(axes_mask=0x01)
2020-05-15 15:58:58,153 - Recv: 0 step=50 mscnt= 806
2020-05-15 15:58:58,160 - Recv: tmc2130_goto_step 0 61 2 1000
2020-05-15 15:58:58,227 - Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01
2020-05-15 15:58:58,339 - Recv: tmc2130_home_enter(axes_mask=0x02)
2020-05-15 15:58:58,548 - Recv: echo:busy: processing
2020-05-15 15:58:59,698 - Recv: 0 step=50 mscnt= 801
2020-05-15 15:58:59,711 - Recv: tmc2130_goto_step 1 49 2 1000
2020-05-15 15:58:59,759 - Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02
2020-05-15 15:58:59,872 - Recv: echo:enqueing "CRASH_RECOVER"
2020-05-15 15:59:01,989 - Recv: echo:busy: processing
2020-05-15 15:59:02,234 - Recv: echo: cold extrusion prevented
2020-05-15 15:59:02,238 - Recv: Resend: 32
2020-05-15 15:59:02,248 - Recv: ok
2020-05-15 15:59:02,253 - Send: N32 G1 X60.000 Y-3.000*0
2020-05-15 15:59:02,257 - Recv: ok
2020-05-15 15:59:02,262 - Send: N33 M400*23
2020-05-15 15:59:02,266 - Recv: ok
2020-05-15 15:59:02,270 - Send: N34 M114*16
2020-05-15 15:59:02,772 - Recv: ok
2020-05-15 15:59:02,778 - Recv: X:60.00 Y:-3.00 Z:0.65 E:0.00 Count X: 59.45 Y:-2.41 Z:0.81 E:-1.00
2020-05-15 15:59:02,787 - Recv: ok
2020-05-15 15:59:02,825 - Send: N35 G91*39
2020-05-15 15:59:02,833 - Recv: ok
2020-05-15 15:59:02,843 - Send: N36 G1 Z-0.500*97
2020-05-15 15:59:02,855 - Recv: ok
2020-05-15 15:59:02,870 - Send: N37 G1 F3000.0*103
2020-05-15 15:59:02,887 - Recv: ok
2020-05-15 15:59:02,894 - Send: N38 G90*43
2020-05-15 15:59:02,918 - Recv: ok
2020-05-15 15:59:02,926 - Send: N39 G1 F1000.000*107
2020-05-15 15:59:02,939 - Recv: ok
2020-05-15 15:59:02,951 - Send: N40 M73 Q0 S302*32
2020-05-15 15:59:02,963 - Recv: NORMAL MODE: Percent done: 0; print time remaining in mins: 299
2020-05-15 15:59:02,968 - Recv: SILENT MODE: Percent done: 0; print time remaining in mins: 302
2020-05-15 15:59:02,971 - Recv: ok
2020-05-15 15:59:02,973 - Send: N41 M73 P0 R299*34
2020-05-15 15:59:02,981 - Recv: NORMAL MODE: Percent done: 0; print time remaining in mins: 299
2020-05-15 15:59:02,987 - Recv: SILENT MODE: Percent done: 0; print time remaining in mins: 302
2020-05-15 15:59:02,990 - Recv: ok
2020-05-15 15:59:03,002 - Send: N42 G1 X100.0 F1000.0*48
2020-05-15 15:59:03,023 - Recv: ok
2020-05-15 15:59:03,028 - Send: N43 G92 E0.0*110
2020-05-15 15:59:03,036 - Recv: ok
2020-05-15 15:59:03,041 - Send: N44 M221 S95*109
2020-05-15 15:59:03,048 - Recv: ok
2020-05-15 15:59:03,055 - Send: N45 G21*43
2020-05-15 15:59:03,060 - Recv: Unknown G code: $45 G21
2020-05-15 15:59:03,062 - Recv: ok
2020-05-15 15:59:03,068 - Send: N46 G90*34
2020-05-15 15:59:03,072 - Recv: ok
2020-05-15 15:59:03,079 - Send: N47 M83*43
2020-05-15 15:59:03,082 - Recv: ok
2020-05-15 15:59:03,087 - Send: N48 M900 K30*126
2020-05-15 15:59:05,207 - Recv: echo:busy: processing
2020-05-15 15:59:05,425 - Recv: echo:Advance K=30.00
2020-05-15 15:59:05,430 - Recv: E/D=Auto
2020-05-15 15:59:05,433 - Recv: ok
2020-05-15 15:59:05,443 - Send: N49 G92 E0.0*100
2020-05-15 15:59:05,449 - Recv: ok
2020-05-15 15:59:05,461 - Send: N50 G1 F2100.0*102
2020-05-15 15:59:05,466 - Recv: ok
2020-05-15 15:59:05,477 - Send: N51 G1 Z0.600 F10800.000*15
2020-05-15 15:59:05,488 - Recv: ok
2020-05-15 15:59:05,500 - Send: N52 G1 X67.259 Y77.258*30
2020-05-15 15:59:05,518 - Recv: ok
2020-05-15 15:59:05,532 - Send: N53 M105*17
2020-05-15 15:59:05,542 - Recv: ok T:38.0 /0.0 B:31.9 /0.0 T0:38.0 /0.0 @:0 B@:0 P:29.2 A:31.9
2020-05-15 15:59:05,556 - Send: N54 G1 Z0.200*79
2020-05-15 15:59:05,569 - Recv: ok
2020-05-15 15:59:05,580 - Send: N55 G1 F2100.0*99
2020-05-15 15:59:05,599 - Recv: ok
2020-05-15 15:59:05,603 - Send: N56 M204 S1000*100
2020-05-15 15:59:05,608 - Recv: ok
2020-05-15 15:59:05,612 - Send: N57 G1 F1200.000*97
2020-05-15 15:59:05,618 - Recv: ok
2020-05-15 15:59:05,621 - Send: N58 G1 Y76.616 X67.604*23
2020-05-15 15:59:05,631 - Recv: ok
2020-05-15 15:59:05,634 - Send: N59 M400*27
2020-05-15 15:59:06,242 - Recv: ok
2020-05-15 15:59:06,246 - Send: N60 M114*17
2020-05-15 15:59:06,255 - Recv: X:67.60 Y:76.62 Z:0.20 E:0.00 Count X: 67.06 Y:77.20 Z:0.40 E:0.00
2020-05-15 15:59:06,261 - Recv: ok
2020-05-15 15:59:06,288 - Send: N61 G1 F4020.0*97
2020-05-15 15:59:06,294 - Recv: ok
2020-05-15 15:59:06,297 - Send: N62 G91*37
2020-05-15 15:59:06,302 - Recv: ok
2020-05-15 15:59:06,307 - Send: N63 G1 Z0.500 F6000.000*50
2020-05-15 15:59:06,331 - Recv: ok
2020-05-15 15:59:06,338 - Send: N64 G90*34
2020-05-15 15:59:06,355 - Recv: ok
2020-05-15 15:59:06,363 - Send: N65 G1 X247.500 Y217.770*26
2020-05-15 15:59:06,399 - Recv: ok
2020-05-15 15:59:06,405 - Send: N66 M400*23
2020-05-15 15:59:07,584 - Changing monitoring state from "Printing" to "Cancelling"
2020-05-15 15:59:07,975 - Recv: echo:enqueing "G1 E-1.000 F2700"
2020-05-15 15:59:07,988 - Recv: echo:enqueing "G1 Z10.702 F800.000"
2020-05-15 15:59:07,992 - Recv: echo:enqueing "CRASH_DETECTEDX"
2020-05-15 15:59:07,995 - Recv: echo: cold extrusion prevented
2020-05-15 15:59:08,837 - Recv: tmc2130_home_enter(axes_mask=0x01)
2020-05-15 15:59:10,052 - Recv: echo:busy: processing
2020-05-15 15:59:12,116 - Recv: echo:busy: processing
2020-05-15 15:59:14,180 - Recv: echo:busy: processing
2020-05-15 15:59:14,510 - Recv: 0 step=62 mscnt= 992
2020-05-15 15:59:14,512 - Recv: tmc2130_goto_step 0 61 2 1000
2020-05-15 15:59:14,569 - Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01
2020-05-15 15:59:14,681 - Recv: tmc2130_home_enter(axes_mask=0x02)
2020-05-15 15:59:16,301 - Recv: echo:busy: processing
2020-05-15 15:59:18,368 - Recv: echo:busy: processing
2020-05-15 15:59:18,827 - Recv: 0 step=49 mscnt= 797
2020-05-15 15:59:18,831 - Recv: tmc2130_goto_step 1 49 2 1000
2020-05-15 15:59:18,888 - Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02
2020-05-15 15:59:19,002 - Recv: echo:enqueing "CRASH_RECOVER"
2020-05-15 15:59:21,137 - Recv: echo:busy: processing
2020-05-15 15:59:23,201 - Recv: echo:busy: processing
2020-05-15 15:59:24,004 - Recv: echo: cold extrusion prevented
2020-05-15 15:59:24,012 - Recv: Resend: 65
2020-05-15 15:59:24,025 - Recv: ok
2020-05-15 15:59:24,030 - Send: N65 G1 X247.500 Y217.770*26
2020-05-15 15:59:24,031 - Recv: ok
2020-05-15 15:59:24,036 - Send: N66 M400*23
2020-05-15 15:59:24,045 - Recv: ok
2020-05-15 15:59:24,049 - Send: N67 M114*22
2020-05-15 15:59:24,988 - Recv: ok
2020-05-15 15:59:24,993 - Send: N68 M108*20
2020-05-15 15:59:24,997 - Recv: X:247.50 Y:211.91 Z:0.70 E:0.00 Count X: 246.96 Y:212.50 Z:1.31 E:-1.00
2020-05-15 15:59:25,006 - Recv: ok
2020-05-15 15:59:25,012 - Recv: Unknown M code: $68 M108
2020-05-15 15:59:25,015 - Send: N69 M84*32
2020-05-15 15:59:25,018 - Recv: ok
2020-05-15 15:59:25,024 - Send: N70 M104 T0 S0*22
2020-05-15 15:59:25,202 - Recv: ok
2020-05-15 15:59:25,209 - Send: N71 M105*17
2020-05-15 15:59:25,210 - Recv: ok
2020-05-15 15:59:25,219 - Send: N72 M140 S0*80
2020-05-15 15:59:25,220 - Recv: ok T:37.5 /0.0 B:31.9 /0.0 T0:37.5 /0.0 @:0 B@:0 P:29.1 A:32.0
2020-05-15 15:59:25,228 - Recv: ok
2020-05-15 15:59:25,235 - Send: N73 M106 S0*83
2020-05-15 15:59:25,240 - Recv: ok
2020-05-15 15:59:25,243 - Send: N74 G1 Z5*84
2020-05-15 15:59:25,434 - Recv: ok
2020-05-15 15:59:25,438 - Send: N75 G1 X0 Y180 F9000*125
2020-05-15 15:59:25,496 - Recv: ok
2020-05-15 15:59:25,500 - Changing monitoring state from "Cancelling" to "Operational"
GCode:
M73 P0 R75
M73 Q0 S75
M201 X1000 Y1000 Z1000 E5000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1250 R1250 T1250 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E4.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
M862.3 P "MK3S" ; printer model check
M862.1 P0.4 ; nozzle diameter check
M115 U3.8.1 ; tell printer latest fw version
G90 ; use absolute coordinates
M83 ; extruder relative mode
M104 S215 ; set extruder temp
M140 S70 ; set bed temp
M190 S70 ; wait for bed temp
M109 S215 ; wait for extruder temp
G28 W ; home all without mesh bed level
G80 ; mesh bed leveling
Octoprint.logs
2020-05-15 15:57:21,454 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-05-15 15:57:21,464 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2020-05-15 15:57:38,347 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-05-15 15:57:43,129 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2020-05-15 15:57:48,506 - octoprint.util.comm - INFO - Could not enter programming mode on /dev/ttyAMA0: u'Timeout'
2020-05-15 15:57:53,860 - octoprint.util.comm - INFO - Could not enter programming mode on /dev/ttyS0: u'Timeout'
2020-05-15 15:57:53,866 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-05-15 15:57:58,436 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-05-15 15:57:58,451 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-05-15 15:57:59,470 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-15 15:57:59,492 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-05-15 15:57:59,511 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-15 15:57:59,561 - octoprint.util.comm - INFO - Printer reports firmware name "Prusa-Firmware 3.8.1 based on Marlin"
2020-05-15 15:58:23,995 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Raspberry_Body_P3B-.gcode, owner: Radeonx, user: Radeonx
2020-05-15 15:58:24,016 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-05-15 15:58:24,026 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Raspberry_Body_P3B-.gcode, owner: Radeonx, user: Radeonx
2020-05-15 15:58:24,077 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-05-15 15:58:24,105 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-15 15:58:26,302 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-05-15 15:58:32,750 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2020-05-15 15:59:02,241 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 32, current line = 34
| Last lines in terminal:
| Recv: ok
| Send: N33 M400*23
| Recv: Resend: 32
2020-05-15 15:59:07,585 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-05-15 15:59:07,609 - octoprint.util.comm - INFO - Force-sending M108 to the printer
2020-05-15 15:59:07,629 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: Raspberry_Body_P3B-.gcode, owner: Radeonx, user: Radeonx
2020-05-15 15:59:24,018 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 65, current line = 67
| Recv: Resend: 65
2020-05-15 15:59:25,501 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
