Octopi disconnects from the printer. No error code on printer. Octopi returns "Too many consecutive timeouts, printer still connected and alive?"
Graph temperature shows this, then printer resets
Terminal returns:
"Recv: echo:SD card ok
Recv: I2C_EEPROM Check Successed!
No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Printing" to "Offline after error"
Connection closed, closing down monitor"
-Safe Mode
-New USB cable (tried 2 new cables)
-PID autotune (was able to complete successfully, probably not a heater cartridge error)
-Set Temp, is able to maintain desired temperature not using the gcode file
-New SD card, with new flash of octopi 0.18.0 and octoprint 1.7.3
yes
no
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.99 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 914010112
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.safe_mode: False
octoprint.version: 1.7.3
systeminfo.generator: zipapi
Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Ender 3 pro, silent board v4.2.7
