Wardus
June 15, 2023, 1:35am
1
My printer shuts itself down after less than a minute of heating up. It reports an M112 error and requires a full reset of the printer. I heard somewhere that this is an Octoprint-related issue, so I have updated my python and octoprint version to their most recent revision. Please keep in mind that I'm not very technical, so please explain stuff to me like I'm 13. If you need any more info, let me know. Thanks!
I have updated everything, even Python.
Yes
octoprint.log (35.4 KB)
plugin_pluginmanager_console.log (11.7 KB)
plugin_softwareupdate_console.log (223.7 KB)
serial.log (148 Bytes)
tornado.log (27.7 KB)
OctoPrint version - 1.9.0, OctoPi version - 0.17.0, Prusa MK3S
Hello @Wardus !
No, it's definitely not. (What people tell when they are bored )
Thermal runaway is a hardware issue with your printer.
In your case with the heated bed:
| Last lines in terminal:
| Recv: T:214.95 E:0 B:21.6
| Recv: T:214.9 /215.0 B:21.6 /60.0 T0:214.9 /215.0 @:30 B@:127 P:28.0 A:26.7
| Recv: T:215.05 E:0 B:21.6
| Recv: T:215.16 E:0 B:21.6
| Recv: T:215.1 /215.0 B:21.4 /60.0 T0:215.1 /215.0 @:27 B@:127 P:28.0 A:26.6
| Recv: T:214.84 E:0 B:21.5
| Recv: T:215.00 E:0 B:21.4
| Recv: T:215.2 /215.0 B:21.8 /60.0 T0:215.2 /215.0 @:25 B@:127 P:28.0 A:26.8
| Recv: T:214.69 E:0 B:22.1
| Recv: T:215.05 E:0 B:21.4
| Recv: T:214.9 /215.0 B:21.4 /60.0 T0:214.9 /215.0 @:30 B@:127 P:28.0 A:26.7
| Recv: T:214.90 E:0 B:21.2
| Recv: T:215.0 /215.0 B:22.2 /60.0 T0:215.0 /215.0 @:28 B@:127 P:28.1 A:26.7
| Recv: T:215.10 E:0 B:22.3
| Recv: T:214.8 /215.0 B:21.2 /60.0 T0:214.8 /215.0 @:32 B@:127 P:28.0 A:26.9
| Recv: T:214.64 E:0 B:21.2
| Recv: LCD status changed
| Recv: Error: THERMAL RUNAWAY (PREHEAT HEATBED)
The bed is set to 60Β°C but the temperature does not change.
Either
the thermistor is detached from the bed
the bed has no connection to the printer board
the power supply fails.
Check the wiring and connectors. You may take this as a guide:
https://help.prusa3d.com/guide/7-heatbed-psu-assembly-textile-sleeve_72744w
system
Closed
September 13, 2023, 6:08am
3
