The printing stops midway. This happens intermittently.
Read here, searched
octoprint.log:
2019-04-11 15:32:59,919 - octoprint.util.comm - INFO - Communication timeout while idle, trying to trigger response from printer.
2019-04-11 15:36:02,658 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-04-11 15:36:02,700 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-11 15:37:25,264 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 15:39:51,996 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2019-04-11 15:39:52,482 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2019-04-11 15:39:55,643 - octoprint.util.comm - INFO - Changing monitoring state from "Paused" to "Cancelling"
2019-04-11 15:39:55,808 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2019-04-11 15:41:39,291 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_Sealant_Cardridge_Cap_V3.gcode
2019-04-11 15:41:39,294 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_Sealant_Cardridge_Cap_V3.gcode
2019-04-11 15:41:46,494 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CE3_Sealant_Cardridge_Cap_V3.gcode finished, needed 7.20s
2019-04-11 15:42:27,226 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-04-11 15:42:27,292 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-11 15:48:13,084 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2019-04-11 15:48:13,324 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2019-04-11 15:49:57,959 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_Sealant_Cardridge_Cap_V3.gcode
2019-04-11 15:49:57,963 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_Sealant_Cardridge_Cap_V3.gcode
2019-04-11 15:50:05,308 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-04-11 15:50:05,333 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-11 15:52:25,267 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 16:07:25,269 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 16:19:25,247 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.127
2019-04-11 16:19:27,084 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.127
2019-04-11 16:19:27,287 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.127
2019-04-11 16:19:29,487 - octoprint.plugins.announcements - INFO - Loaded channel _important from Important OctoPrint Announcements in 0.71s
2019-04-11 16:19:30,653 - octoprint.plugins.announcements - INFO - Loaded channel _releases from OctoPrint Release Announcements in 0.77s
2019-04-11 16:19:31,535 - octoprint.plugins.announcements - INFO - Loaded channel _blog from OctoBlog in 0.78s
2019-04-11 16:19:32,406 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from OctoPrint Plugin Repository in 0.78s
2019-04-11 16:19:33,348 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from OctoPi Announcements in 0.8s
2019-04-11 16:19:53,881 - tornado.access - WARNING - 404 GET /dryrun-activated (::ffff:192.168.1.127) 22.21ms
2019-04-11 16:21:00,273 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.127
2019-04-11 16:21:00,450 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.127
2019-04-11 16:22:25,272 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 16:28:37,883 - octoprint.util.comm - INFO - Finished in 2312.579 s.
2019-04-11 16:28:37,885 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2019-04-11 16:28:37,895 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_Sealant_Cardridge_Cap_V3.gcode
2019-04-11 16:28:37,903 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_Sealant_Cardridge_Cap_V3.gcode
2019-04-11 16:28:37,983 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2019-04-11 16:28:50,965 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CE3_Sealant_Cardridge_Cap_V3.gcode finished, needed 13.07s
2019-04-11 16:37:25,275 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 16:44:30,274 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_hotglue_gun_stand_ext.gcode
2019-04-11 16:44:30,276 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_hotglue_gun_stand_ext.gcode
2019-04-11 16:44:47,593 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-04-11 16:44:47,619 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-11 16:52:25,278 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 17:07:25,280 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 17:22:25,285 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 17:37:25,287 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 17:41:44,809 - anywhere.mjpeg_stream - ERROR - [Errno 32] Broken pipe
2019-04-11 17:52:25,289 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 18:06:58,002 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.127
2019-04-11 18:06:58,021 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.127
2019-04-11 18:06:58,034 - tornado.application - ERROR - Exception in callback <functools.partial object at 0x6cbacd20>
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/ioloop.py", line 605, in _run_callback
ret = callback()
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/stack_context.py", line 277, in null_wrapper
return fn(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/transports/websocket.py", line 94, in
self.server.io_loop.add_callback(lambda: self.send_pack(message, binary))
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/sockjs/tornado/transports/websocket.py", line 89, in send_pack
self.write_message(message, binary)
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/websocket.py", line 249, in write_message
raise WebSocketClosedError()
2019-04-11 18:07:25,293 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 18:22:25,295 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 18:37:25,300 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 18:52:25,303 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 19:07:25,306 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 19:22:25,308 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 19:37:25,310 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 19:52:25,312 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 19:59:43,901 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.127
2019-04-11 19:59:44,047 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.127
2019-04-11 19:59:44,198 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.127
2019-04-11 19:59:44,222 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.127
2019-04-11 19:59:46,350 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.127
2019-04-11 20:00:06,539 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.127
2019-04-11 20:07:25,315 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 20:22:25,317 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 20:37:25,319 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 20:52:25,321 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 21:07:25,323 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 21:22:25,327 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 21:37:25,331 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 21:52:25,334 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 21:57:26,300 - octoprint.util.comm - INFO - Finished in 18758.708 s.
2019-04-11 21:57:26,303 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2019-04-11 21:57:26,313 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_hotglue_gun_stand_ext.gcode
2019-04-11 21:57:26,330 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_hotglue_gun_stand_ext.gcode
2019-04-11 21:57:26,484 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2019-04-11 21:58:07,394 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CE3_hotglue_gun_stand_ext.gcode finished, needed 41.08s
2019-04-11 22:07:25,338 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 22:22:25,340 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 22:22:37,012 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_Octopus_v5.5.gcode
2019-04-11 22:22:37,014 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_Octopus_v5.5.gcode
2019-04-11 22:23:02,335 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-04-11 22:23:02,366 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-04-11 22:37:25,344 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 22:48:48,885 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2605, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4681, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2019-04-11 22:48:48,889 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2019-04-11 22:48:48,913 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2605)"
2019-04-11 22:48:48,949 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_Octopus_v5.5.gcode
2019-04-11 22:48:48,964 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_Octopus_v5.5.gcode
2019-04-11 22:50:20,629 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CE3_Octopus_v5.5.gcode finished, needed 91.68s
2019-04-11 22:52:25,346 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 23:07:25,349 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 23:22:25,353 - octoprint.server.heartbeat - INFO - Server heartbeat <3
