Printer froze 20 minutes in to print. Temperatures remained on. OP temp graph shows no abnomalies. Steppers remained fixed for more than 30 seconds, and then released.
System been running flawless for over a year.
Upgraded to OP 1.4.2 and Python 3, around 2 weeks ago. No print issues since then.
Around same time installed the Pushover plugin.
This morning our internet connection bandwidth allocation was exhausted, so we suddenly had no internet connection.
The print appears to have stopped 20 minutes in to the print.
Pushover plugin options in OP was set to send a text & pic Pushover notification every 20 minutes.
I this just a coincidence, or is it likely ( or even a known issue ) that the Pushover plugin ( or whatever part of the Pi OS controls the transmission of the Pushover notices out to the internet ), could freeze the Pi if it can not connect to the internet when trying to send a message ?
Purchased more bandwidth, Restarted the print, and already past the point where it previously stopped, so the gCode is good.
Reset system. Restarted print.
No. did not try safe mode.
Complete Logs
2020-09-30 06:57:28,185 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-09-30 06:57:28,200 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-09-30 06:57:28,236 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-09-30 06:57:33,309 - octoprint.startup - INFO - Blacklist processing done, adding 10 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8)
2020-09-30 06:57:35,488 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-09-30 06:58:13,941 - octoprint.plugins.octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2020-09-30 06:58:14,581 - octoprint.plugin.core - INFO - Found 24 plugin(s) providing 24 mixin implementations, 41 hook handlers
2020-09-30 06:58:19,411 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-09-30 06:58:19,879 - octoprint.server - INFO - Intermediary server started
2020-09-30 06:58:19,882 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-09-30 06:58:21,572 - octoprint.plugin.core - INFO - Found 24 plugin(s) providing 24 mixin implementations, 41 hook handlers
2020-09-30 06:58:22,277 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-09-30 06:58:30,971 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-09-30 06:58:31,752 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2020-09-30 06:58:31,779 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2020-09-30 06:58:31,810 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2020-09-30 06:58:31,832 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2020-09-30 06:58:31,861 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
2020-09-30 06:58:31,889 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2020-09-30 06:58:31,921 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2020-09-30 06:58:31,932 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
2020-09-30 06:58:31,971 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2020-09-30 06:58:31,996 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2020-09-30 06:58:32,015 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2020-09-30 06:58:32,049 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_manage'), Need(method='role', value='plugin_pluginmanager_install')")
2020-09-30 06:58:32,055 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2020-09-30 06:58:32,077 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2020-09-30 06:58:49,192 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 06:58:56,999 - octoprint.util.pip - INFO - Version of pip is 20.2.3
2020-09-30 06:58:57,054 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-09-30 06:58:57,056 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-09-30 06:58:58,718 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-09-30 06:58:59,003 - octoprint.plugin.core - INFO - Initialized 24 plugin implementation(s)
2020-09-30 06:58:59,189 - octoprint.plugin.core - INFO - 24 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2020.6.22) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| Firmware Updater (1.7.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmwareupdater
| Floating Navbar (0.3.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_floatingnavbar
| Fullscreen Plugin (0.0.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Login UI (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/loginui
| M117NavBar (0.1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_M117NavBar
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Pushover (0.3.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pushover
| Sidebar Temp Graph (0.1.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_sidebartempgraph
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2020-09-30 06:58:59,480 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 121413632
| os:
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi Model B Rev 1
| octopi_version: 0.17.0
| python:
| pip: 20.2.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2020-09-30 06:58:59,702 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-09-30 06:58:59,846 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-09-30 06:59:08,132 - octoprint.server - INFO - Shutting down intermediary server...
2020-09-30 06:59:08,273 - octoprint.server - INFO - Intermediary server shut down
2020-09-30 06:59:08,331 - octoprint.events - INFO - Processing startup event, this is our first event
2020-09-30 06:59:08,352 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-09-30 06:59:08,376 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-09-30 06:59:08,455 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-09-30 06:59:08,530 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-09-30 06:59:08,947 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-09-30 06:59:09,588 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-09-30 06:59:09,835 - octoprint.filemanager.analysis - INFO - Starting analysis of local:i3_final_body.gcode
2020-09-30 06:59:09,856 - octoprint.filemanager - INFO - Added 1 items from storage type "local" to analysis queue
2020-09-30 06:59:09,888 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.01 --throttle-lines=100 /home/pi/.octoprint/uploads/i3_final_body.gcode
2020-09-30 06:59:16,012 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 5.9s
2020-09-30 06:59:16,561 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-09-30 06:59:31,990 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 3.3s
2020-09-30 06:59:38,103 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 3.4s
2020-09-30 06:59:43,676 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 06:59:43,815 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-09-30 06:59:43,817 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-09-30 06:59:44,094 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 4.6GB. That is considered sufficient for updating.
2020-09-30 06:59:49,602 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 5.2s
2020-09-30 07:00:14,152 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 1.1e+01s
2020-09-30 07:01:09,193 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 07:01:09,201 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 07:01:09,162 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 07:01:09,156 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 07:01:12,362 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2020-09-30 07:01:27,519 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-09-30 07:02:30,511 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-09-30 07:02:30,535 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-09-30 07:02:38,654 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-09-30 07:02:41,713 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 284}
2020-09-30 07:02:42,868 - octoprint.plugins.pushover - INFO - Connected to Pushover
2020-09-30 07:02:44,000 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.4.2', 'os': 'linux', 'python': '3.7.3', 'pip': '20.2.3', 'cores': 1, 'freq': 700.0, 'ram': 121413632, 'pi_model': 'Raspberry Pi Model B Rev 1', 'octopi_version': '0.17.0', 'plugins': 'sidebartempgraph:0.1.6,pushover:0.3.8,m117navbar:0.1.1,fullscreen:0.0.5,floatingnavbar:0.3.4,firmwareupdater:1.7.0'}
2020-09-30 07:02:46,497 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'version': '1.4.2', 'os': 'linux', 'python': '3.7.3', 'pip': '20.2.3', 'cores': 1, 'freq': 700.0, 'ram': 121413632, 'pi_model': 'Raspberry Pi Model B Rev 1', 'octopi_version': '0.17.0'}
2020-09-30 07:02:49,899 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.1.113/', 'path': '/', 'query_string': 'l10n=en'}
2020-09-30 07:06:54,436 - octoprint.server.preemptive_cache - INFO - ... done in 244.56s
2020-09-30 07:13:19,458 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-09-30 07:17:41,068 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1184}
2020-09-30 07:28:19,490 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-09-30 07:41:26,420 - octoprint.server.util.flask - INFO - Passively logging in user DaveOB from ::ffff:192.168.1.91
2020-09-30 07:41:26,520 - octoprint.access.users - INFO - Logged in user: DaveOB
2020-09-30 07:41:34,415 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.91
2020-09-30 07:41:36,336 - octoprint.events - INFO - Executing a system command
2020-09-30 07:41:37,009 - octoprint.server.util.flask - INFO - Passively logging in user DaveOB from ::ffff:192.168.1.91
2020-09-30 07:41:37,027 - octoprint.access.users - INFO - Logged in user: DaveOB
2020-09-30 07:42:18,535 - octoprint.server.util.sockjs - INFO - User DaveOB logged in on the socket from client ::ffff:192.168.1.91
2020-09-30 07:42:22,292 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-30 07:42:22,580 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 115200
2020-09-30 07:42:22,742 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-30 07:42:23,017 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-30 07:42:32,311 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-30 07:42:36,315 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-30 07:42:36,367 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-09-30 07:42:36,545 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-30 07:42:36,578 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2020-09-30 07:42:36,676 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2020-09-30 07:42:36,731 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin V1; Sprinter/grbl mashup for gen6"
2020-09-30 07:43:19,502 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-09-30 07:45:18,376 - octoprint.filemanager.analysis - INFO - Starting analysis of local:i3_part_head.gcode
2020-09-30 07:45:18,438 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/i3_part_head.gcode
2020-09-30 07:46:12,404 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: i3_part_head.gcode, owner: DaveOB, user: DaveOB
2020-09-30 07:46:12,694 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-09-30 07:46:12,794 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: i3_part_head.gcode, owner: DaveOB, user: DaveOB
2020-09-30 07:46:12,970 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-30 07:46:13,106 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-09-30 07:58:19,522 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-09-30 08:06:15,079 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-09-30 08:06:45,134 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-09-30 08:07:02,356 - octoprint.util.comm - WARNING - Printer sent 'start' while printing. External reset? Aborting job since printer lost state.
2020-09-30 08:07:02,435 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-09-30 08:07:02,454 - octoprint.filemanager.analysis - INFO - Starting analysis of local:i3_part_head.gcode
2020-09-30 08:07:02,479 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/i3_part_head.gcode
2020-09-30 08:07:02,764 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: i3_part_head.gcode, owner: DaveOB, user: None
2020-09-30 08:07:29,182 - octoprint.server.util.flask - INFO - Passively logging in user DaveOB from ::ffff:192.168.1.91
2020-09-30 08:07:29,203 - octoprint.access.users - INFO - Logged in user: DaveOB
2020-09-30 08:07:36,409 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-09-30 08:07:36,617 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.91
2020-09-30 08:07:41,255 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.91
2020-09-30 08:07:41,763 - octoprint.server.util.flask - INFO - Passively logging in user DaveOB from ::ffff:192.168.1.91
2020-09-30 08:07:41,796 - octoprint.access.users - INFO - Logged in user: DaveOB
2020-09-30 08:08:06,611 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-09-30 08:08:17,360 - octoprint.server.util.sockjs - INFO - User DaveOB logged in on the socket from client ::ffff:192.168.1.91
2020-09-30 08:08:36,731 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-09-30 08:08:37,864 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.91
OP 1.4.2 Pi B+ Ethernet connected, printer reprap, Arduino 2560, Marlin
