The printer starts the print, then stops with this error message. I have tried several times, same result. In the logs, it looks like this (a full system export is also attached).
In some of the cases the printer did print some of the first layer before the error occured, but the "busy interval" was still there right before the crash.
I started with Octaprint because I wanted to move the printer to a place where a USB-cable isn't feasable. Prior to doing so, I tested it and everything seemed to work just fine. The place I moved it to has a bit unstable wifi, but does Octa need wifi once the print is recieved and started?! It is also a bit cold, about 13C during the last two prints. The temperature seems to be holding just fine though.
Here's what the log says just prior to the faliure:
2022-10-13 19:44:50,831 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2022-10-13 19:44:51,161 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': 'local', 'file': 'f215e6d8f759ff4a2ec5662fb801839566c12775'}
2022-10-13 19:44:52,876 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2022-10-13 19:50:35,562 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2022-10-13 19:55:06,814 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Printer halted. kill() called!
| Last lines in terminal:
1: tried again a few times
2:Looked through all the mentions of the error message in this forum and on google, but none of them looks quite like it.
Yes I have.
It did not help
[octoprint-systeminfo-20221013193621.zip|attachment]
(upload://iaMbZ8jYHtw8XaTdYMDv1abpxTx.zip) (1.8 MB)
OctoPrint version, OctoPi version: Latest on a R.Pi 4, printer: Ender 3, firmware: Marlin for BL touch, (also have BL touch installed)
as much data as possible
