I am in the process of upgrading my ender 3 with skr 1.3 and tmc2130 drivers both from bigtree. I have managed to get it almost running but this issue has got me. Using octoprint or the lcd i can get printer to home and even mesh level the bed. But i have no control with octoprint trying to manually move hte print head on any axis. Using the lcd i can move everything just fine. Trying a print the printer goes throught the pre print bed level checks heats up fine homes but then just sits there. Looking at the terminal on octoprint i can see the code being sent and recived but its as if marlin is ignoring any sent from octoprint. if i stop the "ghost" print i can again use octoprint to home but have no control over movement.
LCD screen says print stopped but octoprint keeps pumping code at it so octoprint gives me no errors.
I have looked at marlin config and tried octoprint safe mode.
Where or how do i get these?
ender 3 with bigtree skr 1.3 tmc2130 v3 and pi3+ using stock lcd screen
Click on the word logs for further instructions
