I set up my Octoprint and connected to my raspberry pi 4 and when I try to connect it to my printer it says Error: Found printer but there is a connection problem. I have a Flashforge Dreamer.
I Installed the Flashforge plugin from the plugin repository which didn't work.
I dont know
Complete Logs
' @ comm.py:_open_serial:3670
Could not open port unknown device, port:1:4, baudrate 9600, skipping
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
I have octopi 0.18.0, I have a Flashforge Dreamer, I use google and I have windows as a operating system.
