Since yesterday my printer change its state from "printing" to "pause" about 10-15 minutes after start the printjob. Using Octoprint and Klipper. Never had this problem before.
Checked the logs for notices. Nothing helpful. Checked the cable connections. Changed the filament. Tried other (older) printjobs that worked fine before. Checked the gcodes. Checked the configurations. Restarted everything. Replugged any usb. Removed all api devices.
I will try immediatly
Testing...
Octoprint
2024-02-04 13:30:02,950 - octoprint.util.comm - INFO - Starting job on behalf of user octoprint
2024-02-04 13:30:02,956 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2024-02-04 13:30:02,969 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: xyz.gcode, owner: octoprint, user: octoprint
2024-02-04 13:30:03,011 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2024-02-04 13:30:03,023 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2024-02-04 13:30:03,440 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2024-02-04 13:30:04,351 - octoprint.util.pip - INFO - Using "/home/octoprint/oprint/bin/python3 -m pip" as command to invoke pip
2024-02-04 13:30:04,357 - octoprint.util.pip - INFO - pip installs to /home/octoprint/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2024-02-04 13:30:04,358 - octoprint.util.pip - INFO - ==> pip ok -> yes
2024-02-04 13:30:04,826 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2024-02-04 13:30:05,022 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2024-02-04 13:30:10,906 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2024-02-04 13:30:30,097 - octoprint.util.comm - INFO - Externally triggered heatup detected
2024-02-04 13:38:21,550 - octoprint.plugins.octopod - INFO - *** Printer paused for user ***
2024-02-04 13:38:22,411 - octoprint.util.comm - INFO - Printer signalled that it paused, switching state...
2024-02-04 13:38:22,412 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2024-02-04 13:38:22,432 - octoprint.printer.standard.job - INFO - Print job paused - origin: local, path:xyz.gcode, owner: octoprint, user: None
2024-02-04 13:38:22,837 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
Klipper
[2024-02-04 13:29:58,416] INFO: Klipper state: Disconnect
Klipper state: Ready
[2024-02-04 13:32:35,404] INFO: probe at 17.000,0.000 is z=1.890000
[2024-02-04 13:32:38,211] INFO: probe at 17.000,0.000 is z=1.892500
[2024-02-04 13:32:41,017] INFO: probe at 17.000,0.000 is z=1.895000
... a lot of more probes ...
[2024-02-04 13:34:50,934] INFO: probe at 77.000,148.975 is z=1.820000
[2024-02-04 13:34:54,593] INFO: probe at 17.000,148.975 is z=1.870000
[2024-02-04 13:34:57,402] INFO: probe at 17.000,148.975 is z=1.870000
[2024-02-04 13:35:00,208] INFO: probe at 17.000,148.975 is z=1.870000
[2024-02-04 13:35:00,952] INFO: Mesh Bed Leveling Complete
Bed Mesh state has been saved to profile [default]
for the current session. The SAVE_CONFIG command will
update the printer config file and restart the printer.
[2024-02-04 13:38:22,833] INFO: action:paused
OctoPrint version 1.9.3
OctoPi version 0.18.0 (just seen)
printer Ender 5 S1
firmware Klipper 0.12.0
browser Chrome
operating system Windows
